Author Topic: Battery goes flat if not used within 4 days  (Read 1616 times)
BIGDOG
  • Watford
  • For all those jobs that just dont get done
    • T reg 2.5td
« on: 12 January 2010, 12:36:11 »
I have a T reg 2.5 TD and the battery has not got enough power to start the car if it has not been used within 3-4 days. I wounder if there is a power drain from somewhere and if so can I disconnect /sut down any thing?
Wine is sweeter than water. But water's sweeter than dry.
Re: Battery goes flat if not used within 4 days
« Reply #1 on: 12 January 2010, 12:48:37 »
The correct battery is really important on the 2.5 wheisel. Do you know what amp and how old the battery is?
Oh and welcome to the forum :)
unlucky mark mv6
  • tipton,west mids
« Reply #2 on: 12 January 2010, 12:51:04 »
Maybe due to the cold weather seeing as its every 3-4 days.Try using it on a day to day basis,and see what happens. :y
  • Auckland
    • Mazda MPV
« Reply #3 on: 12 January 2010, 12:54:18 »
There have been a number of people reporting that the rechargeable batteries in the power sounder have failed and caused a continuous current drain.
In a few cases they have caught fire  :o
Hannah Judes Dad
    • the misses round the bend
« Reply #4 on: 12 January 2010, 12:57:25 »
I have disconnected my powersounder this morning as a start to cure the battery drain problem.I will know in a few days if this has solved the problem.
BIGDOG
  • Watford
    • T reg 2.5td
« Reply #5 on: 12 January 2010, 13:37:38 »
thanks all - what the . is apower sounder
Hannah Judes Dad
« Reply #6 on: 12 January 2010, 14:13:08 »
It's part of the alarm system and is located on the offside front wing under the scuttle.It is a small black box that has got rechargeable battteries in it that can fail with time then draw excess current from your battery. There is a 'how to' in the maintenance guide.
MickAP
  • South Derbyshire
« Reply #7 on: 12 January 2010, 15:00:07 »
It's here http://www.omegaowners.com/forum/YaBB.pl?num=1220198611
As said in the above posts though get the battery checked out for holding a charge
Mick :y
« Last Edit: 12 January 2010, 15:00:45 by MickAP »
Hannah Judes Dad
« Reply #8 on: 12 January 2010, 15:07:45 »
Mick :y
Thanks Mick.I haven't quite mastered 'how to' operate a computer yet  :y
BIGDOG
  • Watford
    • T reg 2.5td
« Reply #9 on: 12 January 2010, 16:42:29 »
Thanks all - Its of to the how to for me.
KIND REGARDS
Martin
