Author Topic: Broken Pipe  (Read 1719 times)
deejaywardy
  • Grantham
Broken Pipe
« on: 12 January 2010, 15:43:06 »
ive just been out to my car and fitted the new SWITCHOVER SOLENOID VALVE and have noticed that an inlet manifold pipe is split all the way round PIC BELOW so this is another reason its not running so good at the moment im guessing ?
anyone know where i can get a new one from ?
thanks Ben  :y
peter19730
  • manchester
Re: Broken Pipe
« Reply #1 on: 12 January 2010, 15:49:56 »
theres loads of people on here breaking miggies, someone will help you soon i bet
deejaywardy
  • Grantham
Re: Broken Pipe
« Reply #2 on: 12 January 2010, 15:56:04 »
yeh im getting alot of good advice and help off here :) im lovin the forum already ,, things would be so much better if i didnt keep finding little things wrong with the car tho lol but ohh well thats life ,,, i found a pipe on ebay USED £9.74 ,, is that a bit much for a used bit of rubber lol ??
ben
Re: Broken Pipe
« Reply #3 on: 12 January 2010, 15:56:28 »
Any one will fit off a 2.6, 3.2 or a post 98 3.0.
This will cause awful running as it will let un-metered air in.
Plenty of people in the parts section who will have one (loo knee is breaking a 3.0)
deejaywardy
  • Grantham
Re: Broken Pipe
« Reply #4 on: 12 January 2010, 15:58:48 »
thanks mark  :y
deejaywardy
  • Grantham
Re: Broken Pipe
« Reply #5 on: 12 January 2010, 16:19:31 »
could it also cause the car to missfire and shut 2 cylinders down ?
« Last Edit: 12 January 2010, 16:20:16 by deejaywardy »
Abiton
Re: Broken Pipe
« Reply #6 on: 12 January 2010, 16:25:37 »
If you've got a bit of gaffer tape to temporarily 'fix' the leak, you'll find out.  :)
deejaywardy
  • Grantham
Re: Broken Pipe
« Reply #7 on: 12 January 2010, 16:31:12 »
i shall have a go when i get my clutch sorted
unless a can find one cheap in the meantime
thanks :y
Agemo
  • Cleethorpes
  • Insignia
Re: Broken Pipe
« Reply #8 on: 12 January 2010, 19:26:32 »
I was beaten to the Gaffer tape idea, even clingfilm would do to see if it made a difference.
