Author Topic: 1998 2.5 td auto water pump a rad replace  (Read 1627 times)
philglasgow
  • glasgow
« on: 13 January 2010, 10:32:16 »
Hi Folks
Im looking to change both as radiator was leaking during cold spell and i didnt notice, as temp guage dint show any issues ,ive  now  got squealing from engine etc which im assuming is pump due to no water . Ive looked but cant see any how to's on here ive removed the 2 clips that hold the radiator in but it wont budge more than 5 inches upwards and that s with me helping the old radiator out with a trolley jack and a block of wood.
Is there any how to articles for this as im a tight a*se and dont want to pay anyone  for something i can possibly do myself.
thanks
Phil
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: 1998 2.5 td auto water pump a rad replace
« Reply #1 on: 13 January 2010, 10:55:04 »
Probably the air-con pipes still attached?
Also the electrical connections for fans and thermal switch.
philglasgow
  • glasgow
« Reply #2 on: 13 January 2010, 11:00:59 »
they are still connected i was just seeing what was involved, should radiator just lift out without any force??? and am i right that water pump is 3 bolts and will be easier to change with radiator removed?
thanks
Phil
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #3 on: 13 January 2010, 11:10:44 »
Best thing you can do is to goi to the Maintenance Guides section and follow the guides that are given there. Its what I do and I have not been given bum info either!
One or two I have added a little improvement to for my own benefit.
GudLuk
damage consultant
  • falkirk (sunny scotland)
« Reply #4 on: 13 January 2010, 11:56:39 »
Mind if its a auto you'le have the autobox oil cooler pipes to remove
« Reply #5 on: 13 January 2010, 12:10:04 »
Think there are 2 screws near top (small self tappers), the 2 clips, and the oil cooler pipes if auto.
A/C pipes can make it tight.
Pump - remove viscous, remove belt, remove pulley over waterpump, then remove pump. Dead easy
philglasgow
  • glasgow
« Reply #6 on: 13 January 2010, 15:09:48 »
thanks
I ve read that the viscous can be left off  would you advise this???
thanks again for your time
Phil
« Reply #7 on: 13 January 2010, 15:13:14 »
Water pump is easy to replace with rad in place :y
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #8 on: 13 January 2010, 18:13:51 »
In fact a job that's Weasley done :D
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #9 on: 13 January 2010, 19:02:05 »
Yup Pitchfork, I 'stoataly' agree with you...   ;D
I always knew I'd inherit an estate, but I never thought this would be it!
Page created in 1.121 seconds with 16 queries.
