Author Topic: head gasket?  (Read 1327 times)
rjb6323
  • wiltshire
head gasket?
« on: 13 January 2010, 22:19:52 »
hi can anyone please help
i have a 53 plate 3.2 v6 omega and have noticed i have pressure in the coolant system, and loss of coolant.
 my first guess is the head gasket gone but i have no loss of power, no sludge in the oil or coolant and no white smoke.
are there any other faults that could cause this.
all comments are very welcome
thankyou bob
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: head gasket?
« Reply #1 on: 13 January 2010, 22:23:57 »
you do get pressure in the water tank, may be lossing water some were. check all round and look on floor were engine is.
« Last Edit: 13 January 2010, 22:24:21 by Russell_Hill »
rjb6323
  • wiltshire
Re: head gasket?
« Reply #2 on: 13 January 2010, 22:33:51 »
this is more pressure than i would expect, if i take the cap off and start up you can see it straight away
rustym95
Re: head gasket?
« Reply #3 on: 13 January 2010, 22:38:43 »
may have an air lock, only other way to find a leaking head is pressure test the pistons.
rustym95
Re: head gasket?
« Reply #4 on: 13 January 2010, 22:49:44 »
is there pressure in oil?
Re: head gasket?
« Reply #5 on: 14 January 2010, 09:55:49 »
I hope so ::)
Re: head gasket?
« Reply #6 on: 14 January 2010, 14:18:44 »
Re: head gasket?
« Reply #7 on: 14 January 2010, 14:26:00 »
ok couple of easy things first before all this piston testing stuff....
After a run, take off the expansion cap and sniff, does it smell of petrol?
Any excessive white smoke out of the exhaust?
Check the HBV (heater by-pass valve) passenger side, rear of the block, it shunts water to the heater matrix / engine block, this is a common failure. Check that for leaks.
« Last Edit: 14 January 2010, 14:26:15 by tunnie »
Re: head gasket?
« Reply #8 on: 14 January 2010, 14:26:57 »
My rusty translator suggests he means compression test the cylinders
Re: head gasket?
« Reply #9 on: 14 January 2010, 14:30:50 »
My Trusty translator suggests he means compression test the cylinders
Thanks Tunnie, never heard of pressure testing pistons!!  Cylinder compression test may not pick up dodgy head gasket if coolant leak external to cylinders though!!  Would have thought it more sensible to pressure test cooling system  ;)
