Pages: [1] 2 3  All   Go Down
Author Topic: help ,, gear box noise !  (Read 4862 times)
deejaywardy
  • Grantham
« on: 11 January 2010, 17:55:49 »
does anyone know what this could be ?
( ive got a knocking noise coming from the gearbox , stops when i press the clutch down ... car needs a new clutch and thrust bearing anyway which i will be doing soon so just wondered if anyone had an idea incase i need to replace anything else?
and aslo my car has had a missfire when putting foot down and continues to missfire untill the car is switched off and turned back on again then its fine again till you put your foot down again anyideas ??
thanks Ben
deejaywardy
  • Grantham
Re: help ,, gear box noise !
« Reply #1 on: 11 January 2010, 18:24:36 »
had the car on a code reader but dont rember the code i got told , i will try and find out if that will help anyone
davethediver
  • Blackburn, Lancs.
« Reply #2 on: 11 January 2010, 18:41:41 »
Would make it easier ;D ;D
P.A. Caron de Beaumarchais
deejaywardy
  • Grantham
« Reply #3 on: 11 January 2010, 18:43:43 »
i will try and find out soon ,,, still not sure what the gear box noise would be tho ?
davethediver
  • Blackburn, Lancs.
« Reply #4 on: 11 January 2010, 18:51:25 »
Mileage, service history any works completed may all help with an online diagnosis but the codes will help. :y
What makes you think thrust bearing :question
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #5 on: 11 January 2010, 18:57:02 »
put in 4 gear and try to take off, if it slips like crazy then new cluth etc, if it stalls its ok, also may help find what other noise is.  dont do it to many times though.
« Reply #6 on: 11 January 2010, 19:00:32 »
Don`t need a code reader mate. Do the pedal trick http://www.omegaowners.com/forum/YaBB.pl?num=1189022687 :y
deejaywardy
  • Grantham
« Reply #7 on: 11 January 2010, 19:19:34 »
rito will be back in a few just off to try the pedol trick
,, and cuz it knocks when the clutch is up but not when i push the clutch down ???
deejaywardy
  • Grantham
« Reply #8 on: 11 January 2010, 19:26:04 »
ok so i did the pedal trick and got
0650
1110
so i dunno lol ??
davethediver
  • Blackburn, Lancs.
« Reply #9 on: 11 January 2010, 19:51:26 »
P0650 Malfunction Indicator (MI) Control Circuit Open Instrument
P0700 Transmission control system range/performance
P0704 Clutch Switch Input Circuit Malfunction
P1110 Intake Manifold Valve 1 Voltage High
P1110 Intake Manifold Valve 1 Voltage Low
P1110 Intake Manifold Valve 1 Open
HTH probably not like but i tried :y
deejaywardy
  • Grantham
« Reply #10 on: 11 January 2010, 19:53:57 »
HTH ?? so what do those basicly mean then and what is the solution to fixing the problems ?? thanks
« Last Edit: 11 January 2010, 19:55:47 by deejaywardy »
« Reply #11 on: 11 January 2010, 20:08:10 »
0650 - MIL fault - e.g. dash ecu light
1110 - Intake manifold valve 1 - check the connector to the mutliram solenoid on the back of the plenum - passenger side
deejaywardy
  • Grantham
« Reply #12 on: 11 January 2010, 20:10:30 »
would it be the SWITCHOVER SOLENOID VALVE ???
« Reply #13 on: 11 January 2010, 20:11:35 »
Correct, the one at the rear of the plenum.....
As for the noise, can you get a lever behind the lower pulley and see if it will move for and aft slightly?
deejaywardy
  • Grantham
« Reply #14 on: 11 January 2010, 20:16:19 »
so would the SWITCHOVER SOLENOID VALVE being broken or whatever cause the car to have random missfire when up at speed  ??
and i will have to have a look in the morning i cant see anything outside lol but will let you know..
and would this be what i need ??   http://cgi.ebay.co.uk/VAUXHALL-OPEL-OMEGA-VECTRA-SWITCHOVER-SOLENOID-VALVE_W0QQitemZ170264511099QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item27a48e427b
and just a thankyou to everyone for the help im getting :)
« Last Edit: 11 January 2010, 20:20:06 by deejaywardy »
Pages: [1] 2 3  All   Go Up
