Author Topic: Blower trunking  (Read 1602 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Blower trunking
« on: 15 January 2010, 14:17:17 »
Does anybody know if the trunking which takes the blower resistor can be replaced without taking the dashboard off. Both the clips broke on my trunking when replacing the Hedgehog resistor. Have thought about gluing back in but once done that would mean it could not be changed in future. All bright ideas would be received with pleasure,
Mike Collins
  • North of Bristol
Re: Blower trunking
« Reply #1 on: 15 January 2010, 19:06:17 »
It's possible to remove the blower itself, on my facelift anyway, without taking the whole dash out. It was still a long, awful job and there's a chance of breaking clips and plastic tubes.
I'd look hard at a way of wedging the controller in.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Blower trunking
« Reply #2 on: 15 January 2010, 21:55:44 »
Thats what I feared I have experimented with a silicon gasket maker which may do the job I am also going to see if I can screw a support into the trunking, It might end up with super glue and hope that it never again needs replacing
Big_Roger
  • Southampton
Re: Blower trunking
« Reply #3 on: 15 January 2010, 23:49:41 »
Hi,
Sorry, I have not had to do anything like this on my motor, so I don't know just what needs holding, But,
I had to do a lot of repairs to the air distribution trunking on a Safrane I had many years ago.  Very awkward to get at etc but I found Duck Tape and some very long, (or several strung together) wiring cable ties, and some long Jubilee type clips fixed just about everything.
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
