Author Topic: Thank you Snow  (Read 1788 times)
topdogkelv
  • Bristol England
Thank you Snow
« on: 15 January 2010, 18:42:39 »
Ive only just got my miggy back up and running again due to the abs ecu packing up on me just before christmas, And having fixed that problem and starting to fall back in love with the miggy again all this snow has took its toll on the the poor clutch and has started slipping in Forth and Fifth, Does anyone know where i can get a cheep clutch from as money is tight at the moment the clutch needed is for x30xe many thanks if you nice chaps can help me out  :)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Thank you Snow
« Reply #1 on: 15 January 2010, 18:50:59 »
are you sure its the clutch could be water and oil inside. dose make clucth spin in high gear.
topdogkelv
  • Bristol England
Re: Thank you Snow
« Reply #2 on: 15 January 2010, 18:56:02 »
almost certain its the clutch slipping but il get my mate to check out the possability  of water and oil in there  :y
rustym95
Re: Thank you Snow
« Reply #3 on: 15 January 2010, 19:00:24 »
mine did it othere week in snow when they did not clear the road had to clean out with some petrol and leave to dry, it was ok after that all muck of snow just went straight in the breather slit on the bottom. would use clutch cleaner first, I used petrol after it did not work, put in a pump sprayer and the petrol did.
« Last Edit: 15 January 2010, 20:54:38 by Russell_Hill »
Re: Thank you Snow
« Reply #4 on: 15 January 2010, 23:45:40 »
There should be a rubber bung in the hole in the bottom of the bellousing to stop anything getting in there. :y
rustym95
Re: Thank you Snow
« Reply #5 on: 15 January 2010, 23:48:03 »
were do you get one from not seen a listing on one? ;)
Re: Thank you Snow
« Reply #6 on: 16 January 2010, 01:53:13 »
Vx dealer?  :-/
rustym95
Re: Thank you Snow
« Reply #7 on: 16 January 2010, 02:22:13 »
asked there they said it dont have one only 97 onwards.
