Author Topic: Reduced power after Fuel Filter change......  (Read 1176 times)
bigender
  • Bellshill
« on: 19 January 2010, 16:57:04 »
Since changing the fuel filter on my 2.2DTi Facelift model the engine management light comes on intermittently and no acceleration. What might the problem be? I have re-seated the filter seal but still the same. :o
Thanks for all the help people. Was one of the small plastic pipes dunning round the front of the engine to the EGR Valve has come apart at the corner joint.  :y :y
« Last Edit: 20 January 2010, 14:02:12 by bigender »
unlucky mark mv6
  • tipton,west mids
Re: Reduced power after Fuel Filter change......
« Reply #1 on: 19 January 2010, 17:21:23 »
Maybe a stupid question,but have you fitted it with the direction of flow.There should be an arrow on it somewhere. ::) :y
« Reply #2 on: 19 January 2010, 17:22:20 »
almost definately air in the system
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #3 on: 19 January 2010, 18:46:02 »
def need to bleed the fuel on the injector pipe.
« Reply #4 on: 19 January 2010, 20:11:22 »
You have to remove the fuel return pipe are the filter to let the air out whilst running
waspy
« Reply #5 on: 19 January 2010, 22:16:38 »
It could be one of the plastic pipes that attach to the filter top. Check they aren't kinked or twisted.
The filter position is far from ideal :(
