Author Topic: Pulley bearings - common fault?  (Read 3619 times)
hoj
  • BURY
« on: 19 January 2010, 08:39:14 »
Car has developed a noise which seems to be coming from the PULLEY area on the front of engine.
Im no expert but at first i thought it could be air sucking in somewhere but i am sure now that  it sounds like a bearing on one of the pulleys.
So question is is there a common fault with any of the pulley bearings so i could determine which it is likely to be
3.2 Elite in Oyster
GPar
  • Chatham, Kent
Re: Pulley bearings - common fault?
« Reply #1 on: 19 January 2010, 09:30:48 »
Almost certainly the bearing in the auxilliary belt tensioner pulley (top left as you look at the front of the engine). Common problem. About £30 to replace and 5 mins to change. You will only need the bearing/pulley, not the tensioner itself. Don't leave too long as the thing can sieze and leave you stranded.
Geoff
« Last Edit: 19 January 2010, 09:35:17 by GPar »
« Reply #2 on: 19 January 2010, 09:50:17 »
Drop belt off and check all pulleys by hand.  Agreed most likely tensioner pulley (£24 on TC) - to swap undo 15mm nut, remove pulley.  As Haynes says refitting is reverse of removal!!  5min job  :y
unlucky mark mv6
  • tipton,west mids
« Reply #3 on: 19 January 2010, 10:55:12 »
Dont buy a new one mate,just remove it and grease it using the black high temp stuff,like i did,job was a good un. :y
« Reply #4 on: 19 January 2010, 11:38:29 »
Agreed. If the bearing is caught before it wears too much, just prise the seals off carefully, pack with grease and replace seals.
Matchless
  • Nottingham
    • A white van
« Reply #5 on: 19 January 2010, 12:03:49 »
A tensioner, washed out and re-greased seemed fine. Coule of weeks later it failed, slitting the aux belt lengthways. The flailing belt got between the cambelt cover and the backplate and derailled the cambelt. Result... 24 bent valves and two scrap heads. Is it worth the risk?
« Reply #6 on: 19 January 2010, 12:22:02 »
If its making a noise, its worn to much....replace.
If its just dry when you do a cambelt then re-grease
hoj
  • BURY
« Reply #7 on: 19 January 2010, 15:55:40 »
Well it turns out it was the tensioner as its just thrown the belt off and the plastic bit has dissintigrated.
Towed back to local garage now awaiting price.
Have been told i can just get the pully £20 or tensioner £60 but dont understand why i wouldnt need the tensioner???
Anyone
3.2 Elite in Oyster
« Reply #8 on: 19 January 2010, 16:26:32 »
Because the tensioner is a sprung assembly with a pulley mounted on the end of it....the puley has failed so replace just that....the tensioner wil be fine
hoj
  • BURY
« Reply #9 on: 19 January 2010, 17:40:31 »
what is the plastic bit attached to - the new pulley i presume
3.2 Elite in Oyster
Matchless
  • Nottingham
    • A white van
« Reply #10 on: 19 January 2010, 19:49:14 »
The plastic bit is the pulley, there is a bearing inside and the pulley is moulded around it.
Undo the 15mm nut in the middle, take off the old pulley, fit the new one, do up the nut and refit the belt.
As simple as that.
GPar
  • Chatham, Kent
« Reply #11 on: 19 January 2010, 20:12:53 »
I won't say told you so ......oh damn, I just have! Did try to stop you driving it as exactly the same happened to me including the recovery bit. As already said, you just need the pulley and integral bearing. Once replaced, you turn the centre nut to release the tension and enable the belt to be slipped on.
Geoff
« Last Edit: 19 January 2010, 20:13:52 by GPar »
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
« Reply #12 on: 19 January 2010, 21:37:58 »
It's worth sorting it out now before it goes completely.
I've had this problem.  I ignored the burning smell as the the belt started to fray and melt...but I got away with it as it disintegrated just as I got back to where I was staying but fortunately didn't cause any other damage.
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
tomoco
  • leicester
« Reply #13 on: 19 January 2010, 23:00:01 »
Anybody got a part number for just the pulley?. Mine is a bit squeeky just lately especially on cold start first thing in the morning
thanks
« Reply #14 on: 19 January 2010, 23:08:53 »
9157962  - 44L3 Pulley - £23.05 + VAT
But that was 18 months ago ...  :)
« Last Edit: 19 January 2010, 23:09:32 by entwood »
