Author Topic: 2.5TD is it dying? error codes help needed  (Read 4665 times)
Essex Pete
  • Woodford, Essex
« on: 19 January 2010, 12:27:13 »
I have posted up before about some of the problems with my 2.5TD, i.e poor mpg, then it breaking down on me.
I am finding that it is getting difficult to start when it has warmed up.  Also the mpg figures seem poor.  The OBC tells em that i am getting 27.5 Avg, but on my calculations of 477 miles to 62 litres works out at 34.5mpg.  i managed to do 477 miles on this tank, but the OBC was telling me i have 60 miles remaining, but the car kept cutting out on me.
I dont know what is going on with this poxy car.  When i first got it it ran like a dream, but now it all seems to be going wrong.
Do i have a case of a failing fuel pump?  I have had all the lifter pump out of the tank and it all worked properly.  I cant see why it would be cutting out unless it was really empty, in which case my fuel sender has decided to play up.
Does any one have a suggestion of what i need to look for because im starting to loose the will with this car
« Last Edit: 19 January 2010, 13:44:55 by Essex_Pete »
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
Re: 2.5TD is it dying?
« Reply #1 on: 19 January 2010, 12:54:02 »
Ever since  have had my mig, I have never been able to rely on the last 10 litres of the tank, unfortunately learnt the hard way, when the engine dies with about 8 litres left...  So it may just be that you need to be deducting the final few miles off your range.  Not a solution I'm afraid, just the possibility of having to deal with an acceptance...
Essex Pete
  • Woodford, Essex
« Reply #2 on: 19 January 2010, 13:16:58 »
From what i have read quite a few 2.5td owners have to do this.  What annoys me is when i first bought the car i ran it right down until the OBC was showing just 11 miles remaining.  This has all happened int he last 2 months.  typical, all was good during the summer when i could have worke don it, but now its cold ans wet everything seems to be going wrong
Welung666
« Reply #3 on: 19 January 2010, 13:26:04 »
I regularly get mind down to 2 or 3 miles left on the range with no problems. Had it showing 0 a couple of times too ;D ;D
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #4 on: 19 January 2010, 13:33:17 »
On board computer tells lies ignor it
Rely on calculated mpg & you're getting a good figure, best I have ever achieved is 33mpg
Always leave 10 litres minimum in tank
Welung666
« Reply #5 on: 19 January 2010, 13:40:54 »
I normally fill up when it gets down to a quarter of a tank but since my bank account was emptied in November I've not been able to afford to. So it's been getting a tenner here and there.
Essex Pete
  • Woodford, Essex
« Reply #6 on: 19 January 2010, 13:41:49 »
I am thinking that the OBC could be knackered.  but the fuel light had only just come on and the needle hadnt reached the red yet, guess ill have to keep it on the line above red from now on.
thats the best mpg i have had out of it in the last 3 months though.  Worst i had was just after i serviced it, where i only got 380 miles out of a tank
Anyway, i just paperclipped it to see what it had to say for itself
19      Incorrect RPM Signal
64      Fuel Quantity Control Out of Range
82      Sensor Injector Start Incorrect RPM-Signal
92      Cruise Control Device Circuit Open Or Voltage High
Now 19 i can understand as it is not running.
64 i believe is the senso on injector 4? which causes the EML on lift off
what does 82 mean?
92 baffles me, as the car doesnt have cruise control fitted, or is that what it is telling me?
« Last Edit: 19 January 2010, 13:42:08 by Essex_Pete »
Welung666
Re: 2.5TD is it dying? error codes help needed
« Reply #7 on: 19 January 2010, 13:46:43 »
Get a new fuel filter and a tin of Wynns Diesel Magic. Take the old filter off and empty it back into the tank, fill the new filter with the diesel magic, then refit. Then take it for an italian tune up. That should help a little.
EDIT: 92 just means the cruise stalk isn't fitted ;)
« Last Edit: 19 January 2010, 13:47:12 by Welung666 »
Essex Pete
  • Woodford, Essex
« Reply #8 on: 19 January 2010, 13:55:18 »
I did that when i serviced it, and all my problems seem to have stemmed from then.  I guess it wouldnt hurt to give it another shot.  That way i can check the heater element is fitted correctly as well
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #9 on: 19 January 2010, 14:04:13 »
Do the diesel magic trick first, and repeat it in a few days time with a new fuel filter.
Check that the fuel heater is securely tightened to the filter case while you're at it.
Warm starting problems are quite common on these, and there's an easy fix piece of trickery available on Ebay - costs about 30 quid I think.
Suggest you send a PM to Turk for the link for this.
Also, what condition is your battery in?
It needs to be model-specific, and absolutely 100%.
I've cured two by fitting a brand-new good quality battery, (that's assuming the alternator charge-rate and earthing was okay). Both are still warm-starting faultlessly to date, and both batteries although good, were not the magic 100%!
« Last Edit: 19 January 2010, 14:08:01 by Reliance505 »
Essex Pete
  • Woodford, Essex
« Reply #10 on: 19 January 2010, 14:10:23 »
Ill give the diesel magic trick a go at the weekend, need to pick up a new filter.
The battery i am not too sure about.  Its the one fitted when i bought the car.  Never had a problem with it, other than when i ran it flat when i had the previous problem with the lift pump becoming disconnected.  After a charge over night i has been fine all through the cold weather.  I may add a new earth between the batter and engine to rule that out of the equation though
Essex Pete
  • Woodford, Essex
Seth
« Reply #12 on: 19 January 2010, 14:13:58 »
To get you 'out of the s**te, try pouring some cold water over the injection pump when warm.
Bet it starts okay then!
Seth
« Reply #13 on: 19 January 2010, 14:14:51 »
I guess this is what your talking about
http://cgi.ebay.co.uk/Hot-Starting-Fix-BMW-Vauxhall-Opel-Omega-Diesel-M51_W0QQitemZ370308699137QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item56381e5401
That's the tinker mate!
Although I've not tried this, I haven't heard of any problems with them.
« Last Edit: 19 January 2010, 14:16:48 by Reliance505 »
PC Techy
  • Bath
« Reply #14 on: 19 January 2010, 14:15:47 »
code 82 is injector lift sensor (injector no 4), 64 is fuel quantity/position sensor (irc in injection pump)
You can check them at the main ecu plug.
The lift sensor should give you 90-110 ohms  between pins 5 and 12 on the main ecu plug.
The fuel quantity sensor should give you 5.5 - 6.5 ohms between pins 14 and 21 and pins 14 and 39.
DUE TO CUT BACKS, THE LIGHT AT THE END OF THE TUNNEL HAS BEEN SWITCHED OFF
