Author Topic: Temp Gauge  (Read 1207 times)
deejaywardy
  • Grantham
Temp Gauge
« on: 21 January 2010, 22:30:18 »
before the clutch went in my car :( sat on drive now till got moeny to fix it lol ,, my temp gauge in the car used to work as normal then suddenly drop to the bottom for no reason then not raise again till car switched off and turned back on anyone have an idea
thanks Ben :)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Temp Gauge
« Reply #1 on: 21 January 2010, 22:59:18 »
some aked about the same problem dont know were it is now but try that.
Re: Temp Gauge
« Reply #2 on: 21 January 2010, 23:02:02 »
thanks Ben :)
I think I replied to the other question about this. I'd remove the wire from the temp sensor & earth it. If the temp gauge move full deflection ie to hot, then the gauge & wiring is OK. I'd change the sensor first off & go from there. :y
deejaywardy
  • Grantham
Re: Temp Gauge
« Reply #3 on: 22 January 2010, 19:35:31 »
thanks will see how it goes :)
