Author Topic: ECU Exchange  (Read 1030 times)
spudmariner
  • Portsmouth, Hampshire
ECU Exchange
« on: 22 January 2010, 23:23:43 »
I have an Omega 2.5Cd that after an idiot mate borrowing it for a few months has packed up. His garage has said the ECU has had it. If I get a secondhand one, what else do I need to do on fitting it please?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: ECU Exchange
« Reply #1 on: 22 January 2010, 23:30:51 »
you will need the chip thats in the key or if you can live with it, get the key and ignition barrell and then you should be ok  :y
do a paper clip test first and post the results on here  :y
« Last Edit: 22 January 2010, 23:32:02 by tigers_gonads »
Re: ECU Exchange
« Reply #2 on: 22 January 2010, 23:47:52 »
Very rare for the ECU to fail, and very common for garages to condemn them because they don't understand them.
What are the symptoms?
Keivn
spudmariner
Re: ECU Exchange
« Reply #3 on: 23 January 2010, 01:04:52 »
The symptoms are no feed to fuel pump and apparently not to other systems but as I haven't seen the car I dont really know. I'll get down there and do paperclip test when I get a chance. Thanks all.
Re: ECU Exchange
« Reply #4 on: 23 January 2010, 01:07:07 »
OK. Fuel pump is only fed if the ECU detects cranking and the crank sensor is a common failure. Code 19 stored is a clue to this one. Also make sure the immobiliser light is not flashing. A couple of things to check for starters - as it were. ;)
