Author Topic: car wont start  (Read 3036 times)
caran10
  • coventry
car wont start
« on: 21 January 2010, 22:17:36 »
got yet another problem with my miggy
just come back from having a new power steering pump fitted car ran fine but cut out a couple of times then seemed ok apart from sudden loss of power which cleared and ran ok . Parked car at home ,went out about 2 hours later and it wont start , turning over but not firing dont know wether the immobiliser is playing up can it be disconnected hope someone can help
unlucky mark mv6
  • tipton,west mids
Re: car wont start
« Reply #1 on: 21 January 2010, 22:22:11 »
Dont think it would even turn over if it was the immobiliser iirc. :-/
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: car wont start
« Reply #2 on: 21 January 2010, 22:25:03 »
is the engine management light on, we will need to know if any codes are coming up. :y
« Last Edit: 21 January 2010, 22:25:32 by Russell_Hill »
Omega's is a life not just a car. also do ecu codes read and wiped or rest.., fix LCD tv & DVD recorders PS3's and most electrical equipment just e-mail me.
Re: car wont start
« Reply #3 on: 21 January 2010, 22:26:25 »
Will the pedal trick work?
Bet it's the crank sensor ::) ;)
rustym95
Re: car wont start
« Reply #4 on: 21 January 2010, 22:29:14 »
dont know of hand could be a snaped elastic band ;)
Koomorph
  • South London/Surrey
Re: car wont start
« Reply #5 on: 21 January 2010, 22:36:49 »
Do the pedal trick test - similar issues on my 2002 2.6 - turns over but doesn't fire - cuts out when up to operating temp... pedal trick showed crank sensor fault.
Bought the sensor and having it fitted on Saturday (along with a few other bits Daz is sorting out... ) :y
Hope it is that as car hasn't really been driven in the month since it's been bought....
« Last Edit: 21 January 2010, 22:37:37 by Koomorph »
rustym95
Re: car wont start
« Reply #6 on: 21 January 2010, 22:38:57 »
« Last Edit: 21 January 2010, 22:39:21 by Russell_Hill »
caran10
  • coventry
Re: car wont start
« Reply #7 on: 21 January 2010, 22:44:33 »
would faulty crank sensor prevent it starting
rustym95
Re: car wont start
« Reply #8 on: 21 January 2010, 22:46:01 »
yes and others will as well, do test first. :y
caran10
  • coventry
Re: car wont start
« Reply #9 on: 21 January 2010, 22:48:49 »
ok will try that tomorrow and keep my fingers crossed will it run if you disconnect the sensor or is that a stupid question
rustym95
Re: car wont start
« Reply #10 on: 21 January 2010, 22:50:12 »
dont mater if gone or removed still wont start.
Re: car wont start
« Reply #11 on: 21 January 2010, 22:51:11 »
Nope... Wont do anything other than turn over ;) ;)
If it is the sensor, only use genuine Vx part :y :y
Do the test and post the results :y
caran10
  • coventry
Re: car wont start
« Reply #12 on: 22 January 2010, 08:46:00 »
done the pedal trick comes up  0100  0335  162
dont know what 162 is cant find details of this code anywhere
RobG
    • 16 plate Mokka. Vivaro
Re: car wont start
« Reply #13 on: 22 January 2010, 09:38:03 »
There`s your answer then. Crank sensor
Dave Elite
  • Ellesmere Port
Re: car wont start
« Reply #14 on: 22 January 2010, 10:23:18 »
Yes it would
« Last Edit: 22 January 2010, 10:23:47 by MV6Dave »
