Author Topic: FUEL WARNING LIGHT  (Read 1444 times)
alimodriver
  • lanarkshire scotland
FUEL WARNING LIGHT
« on: 21 January 2010, 22:45:27 »
I have a 2.6 V6 24 valve 52 plate facelift. I let it run low on fuel.The fuel warning light came on ,and the dash was showing 0 miles remainig... I put fuel in ,and now stil [smiley=embarassed.gif]l 0 miles remain AND the fuel warning light is constantly flashing.How do I get it back to normal ?
Re: FUEL WARNING LIGHT
« Reply #1 on: 21 January 2010, 22:47:17 »
Did you fill it? Maybe the float has stuck in  the lowest position ....  :-/
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 21 January 2010, 22:48:14 »
what dose the fuel say not computer.
alimodriver
« Reply #3 on: 21 January 2010, 23:14:35 »
sorry mate ,even having trouble with my pc now... fuel gauge has dropped to empty too. dont know if i will need to reset it...
« Reply #4 on: 21 January 2010, 23:17:43 »
Did you actually fill it up or just stick a small amount in?
From experience of other Vauxhall models, if you run it low enough for the light to come on it doesn't seem to register fuel added unless it's more than about 20L :y :y
rustym95
« Reply #5 on: 22 January 2010, 00:42:53 »
From experience off other Vauxhall models, if you run it low enough for the light to come on it doesn't seem to register fuel added unless it's more than about 20L :y :y
had mine empty and put £5 in and it moved of empty. clean'd out the tank before changing filter.
« Last Edit: 22 January 2010, 00:43:20 by Russell_Hill »
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #6 on: 22 January 2010, 04:38:33 »
lazydocker said it about right. The tank float has probably got itself stuck.
You need to at least half fill it, more is even better so an upward pressure is applied to the tank float. Going over a few speed humps quickly to give an extra added nudge is an idea too.
I doubt whether the unit itself, or the wiring is faulty if it worked perfectly until you ran it dry. Last resort would be to take the tank unit out of the tank and find out what is making it stick. Its not too bad a job.
GudLuk
« Reply #7 on: 22 January 2010, 05:51:28 »
I thought I'd said that!?  :-/  ;)  ;)  :y
« Reply #8 on: 22 January 2010, 08:06:16 »
But I'll claim credit for it :-X :-X ::) ::) :D :D
« Reply #9 on: 22 January 2010, 14:38:08 »
If only a small amount put in, the software on instrument panel doesn't register it.
As the FC is feed from instrument panel, that doesn't register it either.
alimodriver
« Reply #10 on: 23 January 2010, 21:17:56 »
*** You Guys were right. Just had to put more fuel in to get the float moving. then the dash read out sorted itself... many thanks to *** who replied   :y
