Author Topic: Fuel reset switch  (Read 916 times)
scooterrevo123
Fuel reset switch
« on: 25 January 2010, 12:11:46 »
Hi, I have a 1998 v6 3 litre omega elite, the car cut out on me when I was driving and has not run since (2-months) I was towing a trailer at the time and have been told by a garage that the car may have sensed a rear bump and cut the fuel off therfore, requires resetting as there is no power to the fuel pump/spark this sounds simple but I/we cannot locate it anywhere. I was told it was in the boot area by the latch but I cannot locate it at all. Please could someone help as I am at my witsend...........
Re: Fuel reset switch
« Reply #1 on: 25 January 2010, 12:14:02 »
No reset switch. Is the EML light on. Paperclip it and see if you have any codes. Sounds like crank sensor
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
scooterrevo123
« Reply #2 on: 25 January 2010, 12:40:20 »
Hi Rob, The EML light is not on also the crank shaft sensor was replaced about 12 months ago along with a new coil pack, leads and plugs. Not to sure what you mean by the paper clip test.
« Reply #3 on: 25 January 2010, 12:41:43 »
Click on the red highlighted link in my post
« Reply #4 on: 25 January 2010, 12:44:01 »
So it could well be gone again then... Was it a genuine one?
Check the codes... Bet there's a 19 stored :y :y
scooterrevo123
« Reply #5 on: 25 January 2010, 12:51:23 »
If the engine isnt running does this mean I will get a reading of 31 for no RPM each time if so how do I locate the problem from there.
scooterrevo123
« Reply #6 on: 25 January 2010, 12:56:10 »
As fare as I know it was genuine as he was a ex vauxhall lookers fiter. However I will check with the garage regarding the number 19 stored if this is the case would you recomend replacing the sensor again.
« Reply #7 on: 25 January 2010, 14:35:11 »
Yes, you may get a 31, which can be ignored. If there's a code 19, replace the C/S again, with a genuine one, and I would strongly advise re-routing the cable away from the exhaust as per the guide :y :y
