Author Topic: Valve Stem Oil Seals  (Read 1228 times)
ScottieMV6
  • Swinton, Manchester
« on: 25 January 2010, 14:40:38 »
Statrted the work on refurbishing the heads from my car today. Valve spring compressor seems to work fine and I have removed one valve. However, I can't see how you remove the stem oil seal? It seems to be "welded" to the valve guide?
Anyone tell me the best way to remove them? :y
I'd rather be scared to death than bored to death!!
Re: Valve Stem Oil Seals
« Reply #1 on: 25 January 2010, 14:43:47 »
Long nose pliers.....twist a few times and then pull.
You can get a proper tool
ScottieMV6
« Reply #2 on: 25 January 2010, 14:47:13 »
Thats what I was doing but I just seem to be pulling bits of rubber out so I stopped before I did any damage.
I'll give it another go :y
Hannah Judes Dad
    • the misses round the bend
« Reply #3 on: 25 January 2010, 14:55:12 »
[/highlight]
Don't point the finger at me  :D :D
« Reply #4 on: 25 January 2010, 15:59:32 »
They're just a push fit onto the cylinder head, but as they'll now be pot hard you might need a bit more persuasion  ;)  ;)  ;)
Bent valve
« Reply #5 on: 25 January 2010, 18:06:55 »
I used a sharp pointed stainless steel handled vegetable Knife inserted between the steel sleeve of the seal and the valve guide , a couple of taps with the hammer sliced through the sleeve and they fell off with no harm done, except to the knife which was a bit buggered after 24 valves ::)
