Author Topic: Fuel Consumption!  (Read 1438 times)
star_whites
  • Rotherham
Fuel Consumption!
« on: 25 January 2010, 22:13:10 »
Ok now I know Im heavy footed and do drive a little too fast but I have noticed that my average consumption around town has dropped to 13.5.
What would the usual faults be to cause the consumption to drop. It had an oil/filter change, fuel filter, air filter, and plugs not long ago (within 3000 miles) so I would have though these should be fine but the drop appears quite dramatic.
I have seen that most people state they should be getting around the 18 mark even with a heavy right foot so suggestion would be good!!  ::)
Re: Fuel Consumption!
« Reply #1 on: 25 January 2010, 22:14:58 »
i'd check the breathers, spanking the 3.0 around i get 22mpg.
star_whites
  • Rotherham
« Reply #2 on: 25 January 2010, 22:23:44 »
Thinking about it I do get a slight hunting on tickover, and if I leave it stood running for a long period on tickover after quite some time it will attempt to stall then settle down again and be fine for another 3-4 minutes then try again. Ive checked codes and there are none but I wonder if It could be related.
Whats the best way to get to the breathers??
« Reply #3 on: 25 January 2010, 22:24:47 »
Check the maintenance guide section for the guide  :y
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 25 January 2010, 22:31:10 »
Also clogged injectors could be the issue.
star_whites
  • Rotherham
« Reply #5 on: 25 January 2010, 22:34:50 »
Would blocked breathers give a reduction in power as well??
mathewst
  • Split, Croatia
    • v40
« Reply #6 on: 25 January 2010, 22:37:50 »
Don't think so at least not noticeable (not sure) but they woould cause the cam cover gaskets to leak cause of overpresurizing
