Author Topic: Heat now but  (Read 2438 times)
neilr
  • Barnet, Herts
Heat now but
« on: 24 January 2010, 13:09:32 »
Hi all after heater flush to remove rusty crud finally I have heat in car! But 2 questions there is some sort of pump? attached to o/s wing below header tank what is it whats it for how can i check it works.
The bottom hose does not seem to get as hot as the top hose is this right or am i going to get further problems.
Thanks
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Heat now but
« Reply #1 on: 24 January 2010, 13:25:28 »
whoops. wrong pump; the pump you mentoin is the aux heater pump fitted as std to all plod cars and cars with full winter pacck.
Hoof'land storeman.
neilr
  • Barnet, Herts
Re: Heat now but
« Reply #2 on: 24 January 2010, 13:28:17 »
now i sound stupid whats the winter pack.
also on the bright side I now have a tradeclub card so if any one near needs bits ill help if i can
biggriffin
Re: Heat now but
« Reply #3 on: 24 January 2010, 13:33:17 »
on plod cars its fitted to help the cooling system as they sit for long periods just ticking over so the water pump isnt doing all the work.
Hoof'land storeman.
neilr
  • Barnet, Herts
Re: Heat now but
« Reply #4 on: 24 January 2010, 13:37:10 »
could this be why it appears to run cool at about 85 degrees then and the bottom hose appears cooler.
cheers
biggriffin
Re: Heat now but
« Reply #5 on: 24 January 2010, 14:07:46 »
that sounds like an air lock. if top hose is kin hot and bottom one cold.
Hoof'land storeman.
neilr
  • Barnet, Herts
Re: Heat now but
« Reply #6 on: 25 January 2010, 15:43:02 »
bottom hose is not cold but not quite as hot as the top hose. also you could be right about air lock as coolant low came up on display.
Re: Heat now but
« Reply #7 on: 25 January 2010, 15:48:22 »
Lol.....ok, shall we begin
The aux coolant pump has nowt to do with plod .....it simply gets hot water into the matrix faster while the stat is still shut.....it helps pump nice hot water from the head through the matrix. It was fitted to MV6's and pretty much all the 2.6 and 3.2's
As for the 2 pipes being a different temp....thats a good thing.....because if you pass hot water into a heater....and blast cold air over it the water will cool and the air heat up.....hence one pipe should be colder when its working ok  :y
Simples...Squeek
Abiton
Re: Heat now but
« Reply #8 on: 25 January 2010, 15:51:53 »
If that's with the heating set to 'hot' and the cabin blower on, it's only to be expected.
The matrix is a heat exchanger; hot water in, cold air in, hot air out, slightly cooler water out.
If the return hose were a lot cooler than the feed hose, it might point to reduced flow through the matrix, but a bit cooler is just what I'd expect if you're taking heat out to warm the cabin.
If you hold the revs up at say 2500 for a minute or two, you should see the temperature difference get less, as you'll be pumping the hot coolant through the matrix at a higher flow rate, so it will have less chance to cool on its way through.
***must type faster  ;D***
« Last Edit: 25 January 2010, 15:52:35 by Abiton »
neilr
  • Barnet, Herts
Re: Heat now but
« Reply #9 on: 25 January 2010, 15:52:43 »
Thanks Mark not sure if I explained properly the rad top and bottom hoses are different temp or at least they were yesterday i havent been able to check today as im still at work and swmbo has car will add some a/freeze when i get home though
Boatboy
  • St Albans
Re: Heat now but
« Reply #10 on: 25 January 2010, 21:46:07 »
Turn your ignition on and you should be able to hear and feel the pump running. If it's not running, grasp the pump the palm of your hand and gently flex the electrical connector up and down, side to side with your thumb. If it starts vibrating then it might be like mine and have worn brushes that do not properly meet the commutator. If its not spinning of course, instead of aiding hot water flow around the matrix the static impeller will be restring it, so you either get a new or used replacement pump (90566929), or undo the 4 cross head screws, let the impeller and small washer drop out and see how your heating performs without it.
Thanks
 As previously stated, that means the radiator is dispersing, or radiating away, excess engine heat. Same as the inlet and outlet of you home central heating rads should be about 10-15 degrees different.
Steve
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
neilr
  • Barnet, Herts
Re: Heat now but
« Reply #11 on: 26 January 2010, 15:17:58 »
ok all thanks. added about 500ml antifreeze this morn. ran car and all seems to be much better. heater hot and hoses all about right.
Re: Heat now but
« Reply #12 on: 26 January 2010, 15:22:49 »
Was that of pure? Remember you need to keep it a nice 50/50 ballace with water  :y
neilr
  • Barnet, Herts
Re: Heat now but
« Reply #13 on: 26 January 2010, 15:32:18 »
yes defo undiluted out of unopened 1l bottle
