Author Topic: cant open boot with button on dash  (Read 2706 times)
4candles
« on: 26 January 2010, 17:59:18 »
button on dash wont open boot  but it opens with remote any idears    4candles
davethediver
  • Blackburn, Lancs.
Re: cant open boot with button on dash
« Reply #1 on: 26 January 2010, 18:00:21 »
Does it just not open when key is in ignition :question
P.A. Caron de Beaumarchais
4candles
« Reply #2 on: 26 January 2010, 18:25:07 »
no does not work where ever the key is
davethediver
  • Blackburn, Lancs.
« Reply #3 on: 26 January 2010, 18:30:11 »
Could be a fuse can you post up a bit more of the history on the car, year? And maybe where you are may be local member could help you :y
« Reply #4 on: 26 January 2010, 19:02:01 »
you do have to press and hold???
dodgy button?
less
  • Hemel Hempstead
    • 2.6 auto saloon
« Reply #5 on: 26 January 2010, 19:56:58 »
As Chris says, you have to press and hold the button for a good 4 -6 secs or it won't open.
MickAP
  • South Derbyshire
« Reply #6 on: 26 January 2010, 20:10:29 »
Yep press and hold, I made this mistake when I first tried mine. Expected it to open straight away :-?
Mick ;)
« Reply #7 on: 26 January 2010, 20:29:20 »
...sa safety fing init.
Agemo
  • Cleethorpes
  • Insignia
« Reply #8 on: 26 January 2010, 20:43:50 »
Do the Hilper mod, see How To.  :y
4candles
« Reply #9 on: 26 January 2010, 20:47:14 »
Thanks a lot folks holding the button in works a treat
« Reply #10 on: 26 January 2010, 20:57:31 »
also remember, when the ignition is on, the boot will refuse to open. (another 'feature', which was removed in 2002) Unless you do the hilper mod  :y
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
« Reply #11 on: 26 January 2010, 22:08:00 »
Really? Works straight away on mine...
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #12 on: 26 January 2010, 22:11:25 »
:-? and mine !
cruisetopoland
  • UK
« Reply #13 on: 26 January 2010, 22:22:55 »
Early facelifts like mine have the annoying won't open unless key is out set up, which Vauxhall modified on later facelifts to be a time delay switch which acts as the safety feature instead.
Hilpers mod is good but messes up interior light turning off.
Reckon this could be further worked on to add an additional wire or switch to prevent this.  Anyone?
GaryBC
  • Egham, Surrey
« Reply #14 on: 27 January 2010, 11:53:59 »
Instead of simply cutting the wire, why not wire a small switch into the line so that the boot can be released whenever you like by opening the switch, but can be left to operate 'normally' while the switch is left closed?
