Wishbone bushes
Started by cmeonthemove, 27 January 2010, 18:35:05
cmeonthemove
OK me & Daz are trying to decipher which bushes on the front wishbones needs replacing. From what I can gather from the garage the bushes that have gone are where the rear bushes on the front wishbones on the front suspension meet the chassis via a ball joint & flange pad. Does anyone know if these bushes are related to the steering idler or track rods?
Chris
2.5 Elite
fingers21
Does your steering drag you all over the place when you hit any kind of camber?
cmeonthemove
#2
No but I get a knocking sound when braking on rough surface or going over harsher speed bumps. This topic came up when the garage were inspecting the car pre-MoT.
Chris
2.5 Elite
QuoteOK me & Daz are trying to decipher which bushes on the front wishbones needs replacing. From what I can gather from the garage the bushes that have gone are where the rear bushes on the front wishbones on the front suspension meet the chassis via a ball joint & flange pad. Does anyone know if these bushes are related to the steering idler or track rods?
nope not related, although the movement caused by failed bushes will need to be corected by the steering which will involve the track rod ends and steering idler.
Just change the wishbones usually...?
cmeonthemove
Yes I've just now spoken to Daz and we have decided to change the wishbones anyway. Thanks for your help.
Chris
2.5 Elite
davethediver
Best option IMHO just make sure you use decent ones and not cheap pattern s**t. Daz wouldn't fit crap anyway  :y
"It is not necessary to understand things in order to argue about them."
P.A. Caron de Beaumarchais
