Author Topic: help please  (Read 2927 times)
mikeydut
help please
« on: 29 January 2010, 00:15:37 »
hi i have an omega 2.5 v6 and it turns over and trys to start but fails, when i tuck the spark plugs out and turned it over it didnt seem to spark was thinking could it be the crank sensor or would it be somethink else.
thanks mike :-/
Re: help please
« Reply #1 on: 29 January 2010, 00:16:59 »
Sounds like crank sensor mate - check fault codes - 19=breaked crank sensor  :y
mikeydut
Re: help please
« Reply #2 on: 29 January 2010, 00:21:55 »
how do i check the fault code mate
Hannah Judes Dad
    • the misses round the bend
Re: help please
« Reply #3 on: 29 January 2010, 00:51:35 »
The paperclip test can be found here
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Hope that helps   :)
mikeydut
Re: help please
« Reply #4 on: 29 January 2010, 13:20:39 »
hi i got fault code 19...21...144...145 which is the immobiliser, crank sensor, throttle control sensor... i was woundering where would ur first point of call be???????????
Re: help please
« Reply #5 on: 29 January 2010, 13:21:57 »
Crank sensor
mikeydut
Re: help please
« Reply #6 on: 29 January 2010, 13:23:08 »
how come it is coming up with immobiliser fault??? could that be down to taking the battery off???
Re: help please
« Reply #7 on: 29 January 2010, 13:26:50 »
Crank sensor known to throw spurious codes. Does your EML flash when you`re trying to start the car :question
mikeydut
Re: help please
« Reply #8 on: 29 January 2010, 13:31:59 »
yeah and the car was runin like a dream the it disided not no start , why are all the other codes coming up on the paperclip test???
Re: help please
« Reply #9 on: 29 January 2010, 13:33:51 »
If the EML is flashing check the transponder chip inside the key hasn`t worked loose. (you`ve still got a C/S problem though) Oh, and update your profile, location, car etc :y
« Last Edit: 29 January 2010, 13:34:43 by RobG »
mikeydut
Re: help please
« Reply #10 on: 29 January 2010, 13:38:10 »
i will update it shortly lol keep forgeting is it goin to need a new crank sensor or can it be cleaned and wheres the best place to get 1 lol
Re: help please
« Reply #11 on: 29 January 2010, 13:40:42 »
New and genuine from VX, but, if your EML light is flashing when you`re trying to start it you need to resolve that problem or it will never start
mikeydut
Re: help please
« Reply #12 on: 29 January 2010, 13:47:01 »
so if t is the crank sensor and i fit a new 1 that light should go off if thats the problem????
Re: help please
« Reply #13 on: 29 January 2010, 13:52:55 »
When asked if your EML flashes when trying to start you answered yes, That points to immobiliser problems, so apart from the C/S issue you have an issue with the immobiliser. Have you checked the chip in your key.
mikeydut
Re: help please
« Reply #14 on: 29 January 2010, 13:55:15 »
i have had a look but dont know what to look for??? cant i cut the immobilizer out??
