Author Topic: removing an immobiliser  (Read 1714 times)
mikeydut
« on: 29 January 2010, 19:00:25 »
does anyone know how i would remove an immobiliser on my r reg omega and wheere it is as i have got an immobiliser fault... thanks mike
Re: removing an immobiliser
« Reply #1 on: 29 January 2010, 19:03:16 »
Its by ignition switch.  Car won't start if you removed it.
What is fault, falshing EML? If so, check the transponder is still in key!
unlucky mark mv6
  • tipton,west mids
« Reply #2 on: 29 January 2010, 19:04:12 »
Would have thought it would be a bit of a headache mate,as its all tied in with the alarm system.Why not diagnose the fault and fix it. ;)
« Reply #3 on: 29 January 2010, 19:04:54 »
Gone through all that with him TB http://www.omegaowners.com/forum/YaBB.pl?num=1264724137
Any more ideas
mikeydut
« Reply #4 on: 29 January 2010, 19:08:52 »
vauxhall want to much for a new chip in the key what a bout bypassing the immobiliser???
« Reply #5 on: 29 January 2010, 19:10:32 »
Whereabouts are you located
mikeydut
« Reply #6 on: 29 January 2010, 19:11:44 »
birmingham,?
« Reply #7 on: 29 January 2010, 19:13:57 »
Right. Lets settle this once and for all.  Post 1996 immobilisers cannot be bypassed. Its coded to the engine management.
So:
It appears you've lost the transponder?
Do you have a carpass?
Are you near a Tech2 (see my sig)?
If yes to all of above, contact nearest tech2 owner (they may be able to get transponder for you).
« Reply #8 on: 29 January 2010, 19:14:40 »
Search the area you last took key apart for the small chip.
