Author Topic: Reassurance needed  (Read 1332 times)
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Reassurance needed
« on: 31 January 2010, 11:46:22 »
Hi Guys
Just wanted some reassurance. Had to do a 250 mile drive yesterday stopped half way for pee break when I got back to the car the bloke in the car next to me told me I was leaking fluid. Looked down small trikle running dow the car park. Check then fluid it had the consistency of water, no smell and no taste  :o. The car is running fine there is no loss of level in the expansion tank and the temp remains at a constant 85 Deg Cen.
My assumption if the A/C am I right or should I be investigating further??
Any help greatly appreciated.
Cheers
Re: Reassurance needed
« Reply #1 on: 31 January 2010, 11:49:14 »
Sounds right. Tends to be 2 small patches, in line with back of engine.
johnnybbad
  • chester
« Reply #2 on: 31 January 2010, 11:49:37 »
Could be air con, but always good to investigate where the leak ( if its a leak ) is coming from
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #3 on: 31 January 2010, 11:54:25 »
Thanks guys,
The position of the drips were from the rear of the engine between the two exchuast downpipes and amouted to a small cup full of water.
  • Auckland
    • Mazda MPV
« Reply #4 on: 31 January 2010, 13:28:05 »
Is your scuttle drain clear?
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #5 on: 31 January 2010, 13:31:48 »
Hi Andy H
Yes Skuttle is clear. Entwood showed me how me to do an oil change last week and we ckecked then.
« Reply #6 on: 31 January 2010, 14:54:52 »
Hi Guys
Cheers
Always shake it vigorously (but don't look as if you're enjoying it!) before putting it back in your trousers, that should solve the 'leakage' problem. ;) ;D ;D ;D :y
waspy
« Reply #7 on: 31 January 2010, 14:59:21 »
Hi Guys
Cheers
 ;D ;D ;D
GaryBC
  • Egham, Surrey
« Reply #8 on: 01 February 2010, 16:00:41 »
Hi Guys
Cheers
I'd have thought the weather is too cold at the mo for your a/c to be generating any appreciable amount of condensation. And don't they shut off below about 4degC anyway?
