Author Topic: fuel leak  (Read 1159 times)
geoff
  • thornaby,stockton on tees
fuel leak
« on: 01 February 2010, 14:00:58 »
fuel was leaking from joint of return fuel pipe near tank at rear,repeired with a piece of hose and two jubile clips one on metal pipe and the other to the tank, should be o.k to leave or should i replace the fitting,not leaking any more,advis please should i replace the fitting or leave as it is :y :y :y :y :y
Welung666
Re: fuel leak
« Reply #1 on: 01 February 2010, 14:16:44 »
Is that the pipes attached to the plate on top of the fuel tank?
KillerWatt
Re: fuel leak
« Reply #2 on: 01 February 2010, 16:18:09 »
So long as the "hose" you used is proper fuel line, it shouldn't be any problem at all.
geoff
Re: fuel leak
« Reply #3 on: 01 February 2010, 16:26:16 »
yep
Welung666
Re: fuel leak
« Reply #4 on: 01 February 2010, 16:51:09 »
yep
Common problem, have one here that's not to bad ;)
