Author Topic: Coolant Level  (Read 1017 times)
skippy
Coolant Level
« on: 01 February 2010, 21:08:54 »
I have the warning light for the coolant level on. When I checked the level it was ok. Any ideas as what the problem could be. Thanks
Re: Coolant Level
« Reply #1 on: 01 February 2010, 21:10:21 »
The level sensor, which is part of te header tank, is goosed/sticking. The best fix is a new header tank - about £35  :y  :y
geoff
  • thornaby,stockton on tees
Re: Coolant Level
« Reply #2 on: 01 February 2010, 21:37:26 »
i had this problem,un plug the plug from the bottom of the coolant expansion tank,bridge across the plug with bit of wire warning goes out bobs your uncle,or ya could buy new tank  :y :y :y :y
Re: Coolant Level
« Reply #3 on: 01 February 2010, 21:49:26 »
Unplug and bridge as a check, to ensure it is the sensor goosed (and a permanent bodge if you wish ::)), then replace tank :y :y
geoff
Re: Coolant Level
« Reply #4 on: 01 February 2010, 21:54:23 »
i just bridge mine and left it ,don't see the point of the check coolant most cars don't have this on and check coolant once a week anyway think it's a stupid idea  ;D ;D ;D ;Djust another sensor to go wrong and cost money in to the stealers hands >:( >:( >:( >:( ;D ;D ;D ;D
« Last Edit: 01 February 2010, 21:55:16 by geoff »
