Author Topic: How difficult is it to...  (Read 1079 times)
jamescropley
  • Grantham, Lincs
« on: 02 February 2010, 00:36:59 »
Change the front anti roll bar links? Would i need to replace the bushes aswell?
Cheers
hotel21
  • The Kingdom of Fife
Re: How difficult is it to...
« Reply #1 on: 02 February 2010, 01:25:04 »
Links are quite straightforward to do.
The howtoo is in this lot somewheres...   :y
No need for the antiroll bar bushes unless you have proved they are to blame by use of a prybar etc...  Its most prob the links.....
http://www.omegaowners.com/forum/YaBB.pl?num=1152986949
« Last Edit: 02 February 2010, 01:26:13 by hotel21 »
« Reply #2 on: 02 February 2010, 01:25:16 »
Do you mean the drop links?  If so dead easy mate  :y
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #3 on: 02 February 2010, 03:59:26 »
Its a doddle to change the links, the only hard bit is the arkward nut at the top that can be a spanner all the way off.
Best give it a dose of WD the night before.
Doing mine again today and changing the just over a year old aftermarket clone crap ones with genuine VX/GM ones. I should have took that advice in the first place!
Anti-roll bar bushes very rarely need changing and even then must be done from the top! Noticed that when I had the radiator and bagpipes out! You will probably find that when you have done the links that the knocks will disappear.
GudLuk
« Last Edit: 02 February 2010, 04:03:21 by its.ray »
Page created in 0.018 seconds with 14 queries.
