Author Topic: help coolent leak  (Read 970 times)
dragonlord
  • luton
help coolent leak
« on: 01 February 2010, 19:07:57 »
ok guys any ideas where best to start/ most likely places to look first
omega elite t reg had a small leak for ages never been able to find it try as i mite
but it getting worse lost about  3.5L driving to mk and back from luton
its not the heater bypass as that's poped a while back and has been done
cant see anything other than water collecting on plate under engine.
had it on ramp at garage then can see nothing other than some water around timing cover
mats in side are dry so think heater matrix is ok
im not Sure about water pumps on the v6 is that a possible. i hope not.
is oil cooler cover likely to leek or may be that pipe at back of engine?
any sugestions would be a great help guys im stuck
megaomega123
Re: help coolent leak
« Reply #1 on: 01 February 2010, 19:14:12 »
Hoses that connect near the plenum? May explain the location of the water  :-/
« Reply #2 on: 01 February 2010, 19:19:59 »
Assuming it is coolant you can see, and you can find no obvious leak, it might be worth your while checking the expansion bottle for fine cracks around the filler neck, or it may even be a faulty cap, venting coolant which you wont see whilst driving and may have stopped by the time you check under the bonnet? HTH :y
dragonlord
  • luton
« Reply #3 on: 01 February 2010, 19:28:16 »
phate321 pendelum hoses look ok
philrich funny you should say the cap is leaking a touch
and we were debating that there may be a tiny crack at neck but was hard to see really
but it dont seem wet under res so don't think that other water is coming from there as  and yes its deferentially coolant on plate under engine
as cap been a tiny dribble for a while
could try a new cap and tank from breakers tomorrow
dragonlord
  • luton
« Reply #4 on: 02 February 2010, 12:57:59 »
shame less
BUMP
well that's odd chucked in a a bottle of rad weld last night and topped up with water
drove to scrapy this morning to get a tank and couple of caps wanted a spare to make up a pressure tester cap
then other side of town to grab a few Tyre valves from garage i know.
and it dont seem to be losing any water or any i can tell of
cant see it being a pipe know
hope not the head gasket thing as it a 3L pluss its got full vx service history
plus only got 80k genuine on it 25k of em iv done on  it
im wondering if it was leaking from oil cooler cover
could it have been leaking a bit from water pump
any one have any other ideas
at the moment it got very little antifreeze in there
and cant pull it all apart at moment as me backs bad and i dont fance trying in this cold with a bad back.
was thinking to drop coolant stick on new coolant tank,cap
and refill and see how it gos
good or bad idea ?
if i do that will i lose rad weld out of there?
« Last Edit: 02 February 2010, 12:58:37 by outlaw1234 »
