Author Topic: Estate load cover not very good?  (Read 2223 times)
platty
  • Cambridge
    • BMW 530d Sport
« on: 22 January 2010, 16:28:57 »
Hi guys,
I seem to be having a lot of trouble with the load cover in my estate.
 When I want to remove it I slide it all the way to the rear and it slides out as it should. The trouble is once removed, the bars all fall out of the 2 plastic runner bits and I have to rebuild it every time I want to put the lot back in again.
Do they all work like this or is something broken do you think?  :-/
Regards
Platty
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Estate load cover not very good?
« Reply #1 on: 22 January 2010, 16:32:03 »
there is a plastic part in side ( runner) with teeth on it have a look and see if it is still there if not that is why it keeps falling out. :y
MickAP
  • South Derbyshire
« Reply #2 on: 22 January 2010, 17:15:23 »
Hi guys,
Regards
Platty
Me know understand?....But I'm easily confused :-[
Do you mean the plastic runners that are fixed to the side of the car? :y
Mick ;)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #3 on: 22 January 2010, 18:41:21 »
You've broken it
Matchless
  • Nottingham
    • A white van
« Reply #4 on: 23 January 2010, 23:58:50 »
The latches are knackered in the rail inserts. Look for replacements from a scrapper or ask on here.
There are two types around your year though....look at the 'gear' teeth, they are either straight cut, in-line with the rods or skew cut, at an angle to the rods. You have to find the right inserts.
platty
  • Cambridge
    • BMW 530d Sport
« Reply #5 on: 02 February 2010, 21:57:02 »
Well... apologies for the delay in replying, but thank you for the answers - even though I almost forgot about my thread!
So its the 2 plastic inserts that need relacing then... I think it will probably be easiest if I take a photo before making a request in the parts section. AFAIK they are angle cut - but I had better check.
Ta, Platty
platty
  • Cambridge
    • BMW 530d Sport
« Reply #6 on: 02 February 2010, 21:59:40 »
Hi guys,
Regards
Platty
Mick ;)
Sort of Mick, but the last 3/4 inches each side is a removable section that the load cover collects in before you remove it. It seems that these have a latch mechanism to hold the cross bars in place when the whole assy is removed - mine are pooped  :(
