Author Topic: washer system  (Read 2173 times)
stuvaux
  • Stourbridge, West Midlands
    • 1999 Mig 2.5V6 CDX Estate
    • Dog Training HQ
washer system
« on: 02 February 2010, 21:31:41 »
Hi,
I am having trouble with the windscreen washer system on my miggy.
Both front and back are not working. The motor is working fine....i put it in some water and it came out fine. The pipes dont seem to be blocked as I could blow thru them....just!
Any ideas on what to check?
Thanks,
Stu
Take a look at my Dog Training blog at Dog Training HQ
Re: washer system
« Reply #1 on: 02 February 2010, 21:36:45 »
there is a gauze in the washer bottle, take the motor out from the tank (water will pour out) the hole the pump sits in, has a lip, pull this, it will pull up, and out.
Its a gauze that filters the cr@p out of the water, it often gets blocked  :y
stuvaux
    • Dog Training HQ
Re: washer system
« Reply #2 on: 02 February 2010, 21:45:26 »
Thanks! I will try that tomorrow.  :y
Rog the Dodge
  • Devon
Re: washer system
« Reply #3 on: 02 February 2010, 22:00:58 »
Had the same problem, you werent joking about the crap , blimey it was like seaweed in there ,lol.
All sorted now, i did let the hose run through it for a while,just to flush it all out.
Re: washer system
« Reply #4 on: 02 February 2010, 22:04:00 »
Nope, they can get disgusting  :o
Some bl000dy monkey decided to cut out the gauze on our 3.0 Elite  >:(
I found using an old cup in the garage, filled with boiling water, drop it in, leave for a bit, take it out and blow. (oooo errr  ;D)
Re: washer system
« Reply #5 on: 02 February 2010, 22:07:01 »
Crap is usually caused by using cheap washer additive or washing up liquid :(
Use a decent additive at the right concentration and the problem seems not to ocuur.. :)
Rog the Dodge
  • Devon
Re: washer system
« Reply #6 on: 02 February 2010, 22:14:44 »
Thanks for that tip, i will make sure i have the correct mix from now on, it was not a pretty sight [smiley=shocked.gif]
stuvaux
    • Dog Training HQ
Re: washer system
« Reply #7 on: 02 February 2010, 22:49:02 »
Thanks for all the advice guys!  :y
