Author Topic: aircon rad thing  (Read 3683 times)
dragonlord
  • luton
aircon rad thing
« on: 02 February 2010, 21:58:26 »
well found out where my aircon gas went.
when it was on ramp  yesterday and I was looking for coolant leak
the air con rad seem to be falling apart the one behind main radiator
looks like bottom fell out and there's bit crinkly card stuff falling out of it
how hard are they to change as i aint much of a clue on aircon
and will it cost me a arm and a leg or two
Edd
  • South Ockendon
Re: aircon rad thing
« Reply #1 on: 02 February 2010, 22:12:03 »
quite a bit of work, weld new one in then pressure test then regas
« Reply #2 on: 02 February 2010, 22:13:23 »
No mate its just bolted in  :-? :-?
Edd
  • South Ockendon
« Reply #3 on: 02 February 2010, 22:14:21 »
i meant the pipes
Edd
  • South Ockendon
« Reply #4 on: 02 February 2010, 22:14:40 »
or are the on unions
« Reply #5 on: 02 February 2010, 22:15:08 »
I'm sure one of the guys breaking cars in the "for sale" section will be able to help ..  :)
« Reply #6 on: 02 February 2010, 22:15:26 »
If its just the bottom run, thats ok, mines done it a bit,still works fine.
They are quite fragile and damage easily, wrong time of year to tell, but its its working i'd leave be until it/if fails
  • Auckland
    • Mazda MPV
« Reply #7 on: 02 February 2010, 22:16:36 »
A/C condenser/radiator is in front of the the main engine radiator.
I think they both have aluminium fins that can corrode (and look like soggy cardboard).
« Reply #8 on: 02 February 2010, 22:17:47 »
i meant the pipes.........or are the on unions
You obviously have done one of these before  :o :o
You undo the unions at the end of the pipes mate!
Edd
  • South Ockendon
« Reply #9 on: 02 February 2010, 22:19:45 »
not on the omega hence i wasnt sure about it being unions or not but have on others
dragonlord
  • luton
« Reply #10 on: 02 February 2010, 22:29:18 »
acons not working it blows hot air
was when i got car iv done 25k on it its at 82k now
about 7k ago want really chilling but haven needed it
but that defernatly it the condencer thing in frount main rad
and does look like soggy carboard falling out
if it just a bolt in job i may try my self with a used one
cant really weld it my self
so can you just basically just bolt it in and then have it refilled ?
if so ill have a go when it warmer
its not like i need aircon at the moment and the weather we been having
« Last Edit: 02 February 2010, 22:31:47 by outlaw1234 »
Edd
  • South Ockendon
« Reply #11 on: 02 February 2010, 22:32:34 »
it will need a pressure test to be sure its not got any leaks then regas, im sure someone on here was offering a overhaul for the aircon but cant remember how much
« Last Edit: 02 February 2010, 22:32:53 by eddcole »
« Reply #12 on: 02 February 2010, 22:35:14 »
Simon Omega was .. but he's a long, long way from Luton !! :(
  • Auckland
    • Mazda MPV
« Reply #13 on: 02 February 2010, 22:35:20 »
In principle yes.
It is very important to use new sealing rings and keep everything absolutely clean and dry.
I have had a failed condenser then 3 days later the compressor seal failed.
I got an air conditioning engineer to pressure test mine with nitrogen to find the leaks before it was taken apart.
« Reply #14 on: 02 February 2010, 22:37:04 »
Doesn't need any welding - don't listen to advice from people who haven't done the job!!
Need to remove radiator, see http://www.omegaowners.com/forum/YaBB.pl?num=1265139824
Need to remove residual gas (if any) from a/c system (vac pump - illegal to discharge gas to atmosphere  ;) ) - disconnect air con pipes at unions with a/c rea, unbolt rad and lift out.  To fit reverse of removal.  Refit cooling rad, refill cooling system and bleed.  Leak test a/c and regas.  Not a particularly difficult or long job to do.
[edit]You can get a new one here - £90 http://www.carcooling.co.uk/catalog/Vauxhall_Omega_B_94_03-2348-1.html[/edit]
[edit]Howto with pics for doing this job here - http://www.omegaowners.com/forum/YaBB.pl?num=1186952629[/edit]
HTH  :y
« Last Edit: 02 February 2010, 22:53:05 by dbug »
