Author Topic: Air con died  (Read 2129 times)
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Air con died
« on: 03 February 2010, 15:59:28 »
I had the air con re-gassed last summer and recently the clutch has disengaged and the fans don't turn any more.  I was under the bonnet when it stopped so no works caused it.
Any pointers to where to start?  Heated rear window works so F14 sounds OK.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Edd
  • South Ockendon
Re: Air con died
« Reply #1 on: 03 February 2010, 16:01:07 »
did you run it during the winter otherwise seals crack and leak
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Air con died
« Reply #2 on: 03 February 2010, 16:55:12 »
try checking the plug underneath the compesser,sometimes it gets corroaded as its underneath and gets full of muck.
   jack car up and its on the bottom of the compresser two pin jobby.
Hoof'land storeman.
Debs.
Re: Air con died
« Reply #3 on: 03 February 2010, 17:14:50 »
If the refrigerant-gas pressure is insufficient, I think the low pressure run switch stops the compressor-clutch engaging and fans working......with the same effect if the L.P switch became disconnected or is faulty.
So, my first thought would be gas loss (again) :'(
Chris_H
  • E London/Essex UK
Re: Air con died
« Reply #4 on: 03 February 2010, 17:17:25 »
Thanks.  I will check the compressor connection although that probably wouldn't stop the fans.
Will try to find the pressure switches and buzz them.  Any pointers to where they are?
david_omega
Re: Air con died
« Reply #5 on: 03 February 2010, 17:20:17 »
sensor connected to the silver pipes. the thicker pipe is low pressure gas returning to the compressor, the thiner pipe is high pressure liquid.
should be on the low pressure (thick pipe) somwhere between the bulkhead and the comp.
will be a cylindrical plastic piece joined to that pipe, with a connector going on to it.
i think sounds like low gas pressure tho.
Re: Air con died
« Reply #6 on: 03 February 2010, 17:47:11 »
It might just be low temperature. The handbook states that the air con is disabled under a certain outside temperature (5 degrees C?).
Having said that, mine is still running, but other climate versions might disable it. :-/
TBH, if you're going to get it regassed it's better to do it in warmer weather as it's easier to purge moisture out when the system is vacc'ed out, so probably not worth worrying about it now.   I would find the pressure switch and buzz out the low pressure contacts, though, just to see if that is the problem.
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: Air con died
« Reply #7 on: 03 February 2010, 18:29:35 »
I had mine inside in a spare bay at work ... temp was showing 9 degrees and still it wont work so i take it mine is broken as well .... ( the front fan wont come on ) ... was only regassed in september as well  :-/ :'( :'(
