Author Topic: omega alarm  (Read 2834 times)
steve whiting
  • Southall. West London
omega alarm
« on: 02 February 2010, 14:28:16 »
HELP>>>>
I have broken the remote off my Omega, at first after I locked the door, I could open it again with the key, the alarm would sound until I put the key in the ignition and turn on, I could then use the car as normal
NOW
On opening the door, the alarm sounds and will not go off unless I take the key from ignition and re-lock the doors
Any help would be appreciated whilst I wait for DVLA to send me the V5 (Just bought the car) and get it to a vauxhall dealer
« Last Edit: 02 February 2010, 14:29:14 by stevew292 »
Welung666
Re: omega alarm
« Reply #1 on: 02 February 2010, 14:29:44 »
Until you can get it sorted, reach round from the back door and lock the drivers door, this will lock the car without setting the alarm ;)
Hannah Judes Dad
    • the misses round the bend
Re: omega alarm
« Reply #2 on: 02 February 2010, 14:32:46 »
You will need to disconnect the powersounder to silence the alarm until you get your remote sorted, follow this link http://www.omegaowners.com/forum/YaBB.pl?num=1220198611.As wellung said lock the drivers door from the rear door.Hope it helps.
« Last Edit: 02 February 2010, 14:34:57 by hannahjudesdad »
Re: omega alarm
« Reply #3 on: 02 February 2010, 15:32:18 »
There is a horn in addition to the power sounder which will still sound.
Easiest temporary cure is to lock by reaching in the rear door, IMHO.
steve whiting
Re: omega alarm
« Reply #4 on: 02 February 2010, 17:40:02 »
can do this, however the immobilser has also kicked in and the car will not start :-[
Re: omega alarm
« Reply #5 on: 02 February 2010, 17:43:13 »
You've not recently opened a key & lost the chip from inside have you?  :-/
steve whiting
Re: omega alarm
« Reply #6 on: 02 February 2010, 18:01:55 »
Don't really know. I have the remote but the battery has come away from the circuit board
« Last Edit: 02 February 2010, 18:02:18 by stevew292 »
Re: omega alarm
« Reply #7 on: 02 February 2010, 18:08:15 »
Have a look! The chip lives in the horse shoe part of the key (this bit), nothing to do with the fob part. The  chip is a separate rectangle-ish bit.
Is the management light flashing when you're cranking the car? If not ..... it's not the imobiliser  :y
steve whiting
Re: omega alarm
« Reply #8 on: 02 February 2010, 18:13:20 »
Yes....the management light is flashing all the time I crank the engine over, just looked at the KEY and there is no chip attached
Re: omega alarm
« Reply #9 on: 02 February 2010, 18:20:44 »
You need to look where your key was first opened up, unfortunately not the easiest of things to find .... small & black  :'(  :'(
steve whiting
Re: omega alarm
« Reply #10 on: 02 February 2010, 18:22:37 »
I think that this IS the problem, if I can't find this chip, what are my options, many thanks for your help
Re: omega alarm
« Reply #11 on: 02 February 2010, 18:26:40 »
You need a new (new to you chip) reprogrammed to your key. Depending on where you are in the country, there are a few Tech II's that can do it ....aswel as Vauxhall (I dread to think what they charge)
I'd get your torches out & start looking  :y  :y  :y  :y
Re: omega alarm
« Reply #12 on: 02 February 2010, 18:37:15 »
This is where it is. Update your profile, there might be someone near who can help.  :y
steve whiting
Re: omega alarm
« Reply #13 on: 03 February 2010, 18:07:38 »
Thanks to everyone, I have now found the chip for the key, All I have to do now is buy a new remote and get it reprogrammed :)
Welung666
Re: omega alarm
« Reply #14 on: 03 February 2010, 19:18:21 »
How is your old remote damaged? Martin Imber on here does remote repairs ;)
Page created in 0.025 seconds with 16 queries.
