Author Topic: crank sensor test?  (Read 1320 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
crank sensor test?
« on: 04 February 2010, 10:57:48 »
can anybody help. Is there a way to test a crank sensor? With a
Hoof'land storeman.
Re: crank sensor test?
« Reply #1 on: 04 February 2010, 11:18:16 »
What's your car?
You can do the paper clip test ..... fault code 19 is the crank sensor, but depends on the car.
biggriffin
« Reply #2 on: 04 February 2010, 14:40:17 »
i want to test the sensor with a meter,so it must have a ohms value and how 2 test it. Its a 3.0l.
Hoof'land storeman.
« Reply #3 on: 04 February 2010, 16:24:13 »
not worth the hassle, do a paper clip test on the ECU, if it throws up a code 19 its bust and needs replacing, if not, should be all good.  :y
Page created in 0.008 seconds with 16 queries.
