Author Topic: Egr valve question  (Read 1105 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
Egr valve question
« on: 04 February 2010, 20:36:28 »
Was looking in engine bay today and the egr valve on the engine Has a small black pipe conected to it but it doesn't look like it should be there should it have a pipe connected and if so what's the pipe for?it's on 2.5 BMW engine
cheers!
scream if you want to go faster!!!
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Egr valve question
« Reply #1 on: 05 February 2010, 00:37:49 »
Some TDs have two small-bore pipes on the underside, some have only one pipe plus a vent hole.
Whichever variant that you have, the outer (or only) pipe is connected to the boost sensor which is located on the nearside inner wing. It's a glass-topped filter, which is itself vented to the atmosphere. The small-bore pipe is very similar to that used for the leak-off pipes.
