Author Topic: Omega 2 litre - fast idle problem  (Read 1276 times)
andy757
  • Belchamp Walter
« on: 05 February 2010, 15:57:06 »
Scenario
Engine starts fine from cold or hot.
Engine idles (hunts) between 900rpm and 2100rpm and then eventually calms down to idle at 900rpm.
When driving, the engine runs away with itself as if the throttle is stuck. The idle when stationary then hunts again but calms down after about 4 or 5 times of hunting.
I'm not mechanically minded although could probably tackle minor jobs. If anyone is located near Halstead Essex, or Sudbury Suffolk, I'd appreciate some help because so far, my local garage hasn't found a cure and I can't carry on paying £70 an hour for them to research the problem.
Thanks in anticipation  :D
« Last Edit: 05 February 2010, 15:58:24 by andy757 »
Re: Omega 2 litre - fast idle problem
« Reply #1 on: 05 February 2010, 16:04:15 »
Sounds like the ICV needs a good clean idle should 550-650 http://www.omegaowners.com/forum/YaBB.pl?num=1194007453
« Last Edit: 05 February 2010, 16:05:11 by RobG »
andy757
  • Belchamp Walter
« Reply #2 on: 05 February 2010, 16:24:05 »
I do believe the ICV has already been cleaned.
Jamieo
« Reply #3 on: 05 February 2010, 16:26:35 »
I am fairly sure that it will be the idle control valve too, you might as well give the throttle body and breathers a clean while your on.
Jamieo
« Reply #4 on: 05 February 2010, 16:28:50 »
Could be a faulty ICV. Do you know anybody with one that is known to be good that you could try?
andy757
  • Belchamp Walter
« Reply #5 on: 05 February 2010, 16:43:24 »
An ICV has been installed and it's not made any difference so the old one was put back.
I'm not sure I know what I'm looking for when people make suggestions.
If someone local could pop round, now that would help. I'll cover their petrol costs.
