Author Topic: rear blind problem  (Read 1436 times)
dbr
  • north east.
    • 1997. 2.5CD petrol
rear blind problem
« on: 05 February 2010, 20:46:53 »
Rear blind goes up ok, but stops after a few inches going down. There's lots of  'clicking' then after about 10secs it stops. Could I adjust something or will it be another motor?
« Last Edit: 05 February 2010, 20:58:51 by hotel21 »
puffa
  • Southampton, UK
Re: rear
« Reply #1 on: 05 February 2010, 20:50:35 »
ouch, sounds like the motor, possible there a couple of teeth missing on the main drive cog, not a cheap repair either.... good luck...
one thing to try is with someone else pressing the button  gently push the blind when it stops if it starts again then it is probably the missing teeth, I have had x2 motors now that have done this !!!!
Steve
« Last Edit: 05 February 2010, 20:51:36 by puffa »
Previously owned 2.5 v6 Reflection
dbr
  • north east.
Re: rear
« Reply #2 on: 05 February 2010, 20:55:16 »
Steve
yes that method works to get it down. Sounds like another motor or sticking with the push.....its cheaper.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: rear
« Reply #3 on: 05 February 2010, 21:01:33 »
I had the same on my previous Elite. Mine was the runners sticking in the tracks. One of the pivoting connections had broken and it was causing the sliders to twist enough to jam.
