Author Topic: Order of things  (Read 2242 times)
gstylebaby
  • stockport
Order of things
« on: 05 February 2010, 09:43:41 »
Hi all cutting a long story short have just got new coolant transfer pipe from vauxhall and i'm about to rebuild the car but i can not for the life of me remember the order in which the parts go back on the bas***d bolt is it the oil dipstick pipe then the bracket then the transfer pipe or is it bracket , oil dipstick pipe then transfer pipe ????????  :-? :-?
Re: Order of things
« Reply #1 on: 05 February 2010, 09:47:26 »
got the same problem this evening my thinks on my stat change, believe its transfer pipe, bracket, dipstick for re-assemble :y
« Last Edit: 05 February 2010, 09:47:38 by tunnie »
gstylebaby
  • stockport
Re: Order of things
« Reply #2 on: 05 February 2010, 09:54:07 »
Are you sure tunnie mate only i'm sure the transfer pipe has to go on last as it came off first and all the other part seem flat but that has a angle to it ??? :-[ :-[ Just want to be sure before i put it back together. :y
gstylebaby
  • stockport
Re: Order of things
« Reply #3 on: 05 February 2010, 13:00:50 »
Anyone else no if its the oil dipstick and then the bracket or other way round ?????
Re: Order of things
« Reply #4 on: 05 February 2010, 13:01:48 »
It is
Head - Bracket - Dipstick - Transfer Pipe - Spacer - Bolt head
gstylebaby
  • stockport
Re: Order of things
« Reply #5 on: 05 February 2010, 13:31:56 »
It is
Thanks mark  :y :y...Only i dont think i found a spacer on mine ????
Dave Elite
  • Ellesmere Port
Re: Order of things
« Reply #6 on: 05 February 2010, 13:58:26 »
No i did mine a week ago, MarksDTM is right. He told me and it all went back together well.
Dave Elite
  • Ellesmere Port
Re: Order of things
« Reply #7 on: 05 February 2010, 13:59:59 »
It is
I lost mine and mark told me to cut 5mm of the bolt. I did this and it all went well.
gstylebaby
  • stockport
Re: Order of things
« Reply #8 on: 05 February 2010, 20:31:41 »
i'm not saying that it should not have one mate i'm just saying i did'ent find one on mine i will check under the car and around the area but defo think mine is /was missing any way i've put them in correct oder minus the spacer and bolted it up...Now i found a small hole in the large pipe that goes to the h.b.v to the engine were the temp sensor is. Looks like another trip to vauxhall then or breakers. :'( :'(
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Order of things
« Reply #9 on: 05 February 2010, 20:42:51 »
forget to put the spacer in and the lug on pipe goes "SNAP" did mine couple months ago.
Hoof'land storeman.
gstylebaby
  • stockport
Re: Order of things
« Reply #10 on: 05 February 2010, 21:15:39 »
What does this spacer look like dont suppose anyone has a piccy do they please. :-? :-? Been looking at my e.p.c for ages today and still can not find this spacer?? :-[ :-[
« Last Edit: 05 February 2010, 21:16:44 by gstylebaby »
