Author Topic: Can the pollen-filter 'holder' be taken out?  (Read 3382 times)
nobleone
  • Northam, Devon nr Bideford
« on: 04 February 2010, 12:07:08 »
Hi,
After clearing my scuttle drain because I suspected that it was the cause of water in my passenger footwell  :( , we now know that the cause of the water was not a blocked scuttle drain, it was a leaky scuttle!
Considering how little room for maneuver there is down there, can the pollen-filter holder be removed so we can tackle the rust and seal the scuttle? And if so, how?
Please help - with all this rain I feel like the little Dutchman holding his finger in the d**e, and I still have a small pond in my footwell :'(.
janet
PS I want to say that the Dutchman has his finger in the 'embankment to prevent flooding', but for some reason the word keeps coming up with stars in the middle!
alunonhisown
Re: Can the pollen-filter 'holder' be taken out?
« Reply #1 on: 04 February 2010, 12:10:58 »
Wish I was a dutchman with his finger in a DYKE!!!!!!!!
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 04 February 2010, 12:24:34 »
Are you coming out Diane?
alunonhisown
« Reply #3 on: 04 February 2010, 12:27:07 »
Out Where? :-[ :-[ :-[ :-[ :-[ :-[ :-[ :-[
nobleone
« Reply #4 on: 04 February 2010, 12:43:19 »
Now I know why the 'stars' :-[
If anyone has a serious response to this I'd appreciate hearing it.
janet
« Reply #5 on: 04 February 2010, 12:45:55 »
never heard of anyone removing it.
We have several guides in the maint section on clearing out the drain, some involving a bit of electrix cable to push through the dirt.
then they tend to stay clear, esp with the odd watering can full to help flush out any rubbish.
nobleone
« Reply #7 on: 04 February 2010, 12:59:07 »
Thanks, Jimbob.
The drain is now clear and the scuttle is draining just fine, but obviously previous owners have let water build up in there and rust has led to holes in the sides of the scuttle.
I was hoping we could take out the pollen filter holder to create a bit of space in the scuttle, otherwise I suppose we could try applying sealant with one of those paintbrushes you use behind radiators.
Does anyone have any other ideas?
janet
« Reply #8 on: 04 February 2010, 13:02:34 »
Well I am sure they do come out as one of the breakers on here removed one for me once.
Would imagine its scuttle off etc plus probably glove box out to to get at the internals
Shackeng
  • Ramsbury
« Reply #9 on: 04 February 2010, 13:04:09 »
If the holes are only in the sides, such that it does not flood in when the drain is clear, I would be inclined to fill the holes with a bit of body filler, then paint over. :y
davethediver
  • Blackburn, Lancs.
« Reply #10 on: 04 February 2010, 13:06:45 »
 ;D ;D ;D ;D :y
P.A. Caron de Beaumarchais
nobleone
« Reply #11 on: 04 February 2010, 13:08:13 »
We'll investigate taking the holder off (thanks Marks) and body filler is another good idea (thanks Shackeng).
If we can get the thing off, it will be easy to apply the filler, otherwise it's back to 'keyhole' surgery.
janet
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #12 on: 04 February 2010, 13:09:01 »
Hi
Just a thought, I may be totally wrong and if I am I'm sorry!!! but if you were to remove the glove box like Marks DTM said pull back the passenger footwell carpet can you see the rust holes on the inside?  If so you could patch them up from here - no need to remove the skuttle.
nobleone
« Reply #13 on: 04 February 2010, 13:23:38 »
I've already had the carpet taken up and most of the soundproofing padding, but the man who did it for me left the padding at the front of the footwell because he was afraid he might damage the wiring loom. That might still have to be (very, very carefully) taken out as it's now soaking and I don't know if it will ever dry out otherwise.
But taking out the glovebox is another idea to think about, and I'd much rather work from inside the car than through the scuttle opening.
janet
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #14 on: 04 February 2010, 14:07:11 »
hi janet
update your profile so we know where you are  :y
they might be a member who's near too you  :y
