Author Topic: Flickering Oil Light 2.2 DTi  (Read 1630 times)
unclelicklug
  • Sheffield
« on: 05 February 2010, 16:39:48 »
Hello all - my oil light has started flickering on idle when the engine has warmed up, the car is a '52 2.2DTi with pretty low mileage (about 80k) and the oil is changed regularly - although probably due a change.
Is this a known fault, any pointers?
Thanks!!
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Flickering Oil Light 2.2 DTi
« Reply #1 on: 05 February 2010, 19:35:42 »
if the dip stick says its got enuf then would say wire loose or need a new sensor, try claning the sensor out first as the can get clogged up with road muck and oil. :y
« Reply #2 on: 05 February 2010, 19:37:07 »
Have you checked the level recently?
Richard A
  • Aldridge, West Midlands
« Reply #3 on: 05 February 2010, 19:54:44 »
I found the same problem on the 2.2 diesel Elite I had, inclines on motorways always caused the 'light' to flicker. Best cure, check oil 1 minute after switch off, check oil is at the max mark then add 1/4 litre of oil, it's something to do with the position of the 'oil level pickup'.
regards
richard a
richard a
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #4 on: 05 February 2010, 21:50:49 »
regards
richard a
Why add oil if the dipstick is showing it's at it's max anyway ?  :-?
Richard A
« Reply #5 on: 05 February 2010, 22:05:14 »
Because as I said, on an incline the oil moves to the back of the sump away from the 'level' pick up, it was a 'tip' I was told by a GM engineer, sorted out the problem for over 20k.
regards
richard a
richard a
« Reply #6 on: 05 February 2010, 22:08:27 »
1/4 of a litre sounds a bit excessive if its already on the max mark on the dip stick  :-/
waspy
« Reply #7 on: 05 February 2010, 22:27:21 »
An extra 250mil of oil won't do any harm :)
Page created in 0.059 seconds with 16 queries.
