Author Topic: lift pumps  (Read 1008 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
lift pumps
« on: 06 February 2010, 18:54:22 »
are all migs lift pumps compatible with each other & would one from a petrol work ok in a diesel. thanks in advance.  :y
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: lift pumps
« Reply #1 on: 06 February 2010, 19:28:50 »
would not try it. petrol to petrol diesel to diesel. :y
Omegatoy
  • UK
Re: lift pumps
« Reply #2 on: 06 February 2010, 20:20:54 »
this is not gospel but i believe the pump for the diesel is only a modified petrol unit, and this is shy they often fail early!! however i wouldnt think the petrol one is a direct swap for the diesel one as the pipes are probably a different size!! for sure the pump body is different :y
Page created in 0.008 seconds with 16 queries.
