Author Topic: rear parcel shelf question  (Read 1560 times)
mathewst
  • Split, Croatia
    • v40
« on: 06 February 2010, 22:37:06 »
Had a car in audio shop to fit rear 6x9 speakers, and after two hours trying they said they cannot do it without cutting the metal underneath the shelf.
And they strongly advised against it cause it seems that the metal is a vital support for rear end of the car. Anybody has any advice about this???
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: rear parcel shelf question
« Reply #1 on: 06 February 2010, 22:41:13 »
There should be two plates tack welded in, so you should be able to remove them like I did when fitting Bose rear subs into the rear shelf of my Mv6 :y
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 06 February 2010, 22:44:40 »
is it same on facelift and prefacelift?
mathewst
  • Split, Croatia
    • v40
« Reply #3 on: 06 February 2010, 22:45:34 »
whaat are dimesions and position of those subs Dart?
Thanks
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #4 on: 06 February 2010, 22:48:43 »
Open your boot and have a look mate you should be able to see two round plates :y
mathewst
  • Split, Croatia
    • v40
« Reply #5 on: 06 February 2010, 22:50:35 »
I think I know what you mean but never saw they were welded :-?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #6 on: 06 February 2010, 22:53:10 »
a few tack welds mate..
mathewst
  • Split, Croatia
    • v40
« Reply #7 on: 06 February 2010, 22:54:59 »
But is there a hole above those plates or is there any metal above?
i wasnt in the shop when they removed the shelf so have no idea.
What were the sizes of the subs you fited?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #8 on: 06 February 2010, 23:03:06 »
I cant remember off hand what size the holes are 5-6 inches diametre I would have thought.
Ok. When Bose is fitted into Elites, the inner rear parcel shelf has a rear blind plus two holes, one each side right over the holes in the steel shelf under the inner rear shelf, which then has two Bose Speaker Covers so you cant see the holes in the inner rear shelf.
You need to remove the inner rear shelf to fit the Bose Subs which fit into the holes that the plates filled, the Subs then have about 5 or 6 screws which then screw into the steel shelf which is part of the car body under the inner rear shelf, this is what you see from inside the boot.
Hope this helps :y
mathewst
  • Split, Croatia
    • v40
« Reply #9 on: 06 February 2010, 23:10:29 »
Well will try to use this info
Thanks Darth
« Reply #10 on: 06 February 2010, 23:53:58 »
I have a feeling facelift models don't have the holes for the Bose subs pre-cut.  :-/
