Author Topic: Vibrations  (Read 3062 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Vibrations
« on: 07 February 2010, 12:19:40 »
Hello
Ok i've just been on a long run on motorway ( i dont do motorways very often in my normal day to day stuff ).... im still getting a non constant vibration from 55mph upwards  >:( ...its not through the steering , it feels like the whole car ... i did get the wheels balanced all round a few months ago paying paticular attention to the rears .... this vibration seems to come and go with no pattern to it , can drive a few miles without but then gradually it starts for a while then fades away again ... its not too severe but its there and doesnt make for a nice drive ... i have changed drop links myself a few months back along with steering idler and track rods done at a garage and disks/pads myself again ... no judder on braking .... im wondering if i have a bent wheel but wouldnt that show on balance machine  .... she still tramlines and still feels a bit vauge at speed with lots of little inputs needed on steering... sometimes feels really light and floaty at the front  ... so should i throw more money at her and have wishbones done aswell  :-/ :-/
I may just have answered my own question here but thanks for any suggestions
Oh and looks like my A/C is goosed as well  :'( :'(
Cheers
« Last Edit: 07 February 2010, 15:02:33 by Mark38 »
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Vibrations
« Reply #1 on: 07 February 2010, 12:57:33 »
how dose the propshaft rubber look?? one in the middle. :y
Proz
Re: Vibrations
« Reply #2 on: 07 February 2010, 13:00:20 »
I dont know ... i would need someone that knew what they were doing to look at it .... it would probly look fine to me  :-/
Thanks though .. thats something else i can get checked added to the fault list  :y
rustym95
Re: Vibrations
« Reply #3 on: 07 February 2010, 13:03:10 »
if you under the car grab one shaft with left and one with right and twist like ringing out a towel if it move's easy or any play would say its worn out that would give vibrations, then smoth out.
Proz
Re: Vibrations
« Reply #4 on: 07 February 2010, 13:06:37 »
Nice one .... i think i may be able to try that ... thanks  :y
Now how to get it up far enough to allow my fat belly under as well  ;D
Re: Vibrations
« Reply #5 on: 07 February 2010, 13:08:22 »
[size=14]Please don't get under it using just a jack![/size] Ramps are the best/easiest way.
Proz
Re: Vibrations
« Reply #6 on: 07 February 2010, 13:10:17 »
No i wont do that .... i'll have to wait till i can do it at work ... there are lots of chocks and blocks that can be placed under car to secure it  :y
Re: Vibrations
« Reply #7 on: 07 February 2010, 13:13:39 »
 :y  :y  :y  :y  :y
Proz
Re: Vibrations
« Reply #8 on: 07 February 2010, 13:16:30 »
I'll use all the chocks and blocks that we use to secure crashed cars at accidents etc .... should be safe enough then  :y
Re: Vibrations
« Reply #9 on: 07 February 2010, 13:35:50 »
does it change depending on revs? Or is only high speed?
Proz
Re: Vibrations
« Reply #10 on: 07 February 2010, 13:40:20 »
It would appear NOT to change with revs or accelaration or deceleration ... its only from 50ish upwards .
Re: Vibrations
« Reply #11 on: 07 February 2010, 14:24:19 »
Could be a bucked wheel, hit any big pot holes since the snow? Might be worth swapping front and rears, see if there is any change
Proz
Re: Vibrations
« Reply #12 on: 07 February 2010, 14:51:14 »
Not hit any potholes that i can think of but yes thats something else i can easily try  :y
Proz
Re: Vibrations
« Reply #13 on: 07 February 2010, 14:58:32 »
I dont know how to explain it really but sometimes it feels really light at the front at speed as well ... almost as if its floating  :-/
Re: Vibrations
« Reply #14 on: 07 February 2010, 16:59:46 »
engine mounts.. just changed 10 days ago..
unfortunately not an easy job to do..
will send some related piccies..
« Last Edit: 07 February 2010, 17:02:34 by cem_devecioglu »
