Author Topic: Automatic gearbox fault message on dashboard  (Read 1579 times)
tipon
« on: 07 February 2010, 08:53:30 »
What could be wrong with the automatic gearbox if i have the message on the dashboard? When i get the automatic gearbox check fault message the car accelerate very hardly, it picks up the speed after a while but slowly. thx
Re: Automatic gearbox fault message on dashboard
« Reply #1 on: 07 February 2010, 08:56:58 »
You need the car on a code reader to check the fault, it could be anything. It sounds like your lack of acceleration is because the car is setting off & staying in 3rd gear. My car did the same when I left the throttle position switch off.  ::)  ::)
tipon
« Reply #2 on: 07 February 2010, 09:01:41 »
thx, how much could be the fix it?
« Reply #3 on: 07 February 2010, 09:02:52 »
You don't know what the fault is yes!   ;)  ;)  ;)
tipon
« Reply #4 on: 07 February 2010, 09:07:53 »
oh yes, how truth it is, early morning :o, thx
Humpy
  • Tunbridge Wells, Kent
« Reply #5 on: 07 February 2010, 11:32:27 »
I get this on the MID when I first start the car and I drive a manual :)
Humpy
« Reply #6 on: 07 February 2010, 11:39:57 »
Humpy
Suggests your MID is not the correct one and has been replaced at some point in its life, it needs to be programed with tech2 to match your engine, and spec. MPG readings and so on could be inaccurate  :y
« Reply #7 on: 07 February 2010, 11:41:04 »
Humpy
Has the extra pedal been added since it left the factory?  ;)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
« Reply #8 on: 07 February 2010, 13:45:58 »
I got the same message on my car & limp mode. Turned out to be the cam sensor. Dont know why it ses auto gearbox fault when the cam sensor has gone!!!!!!!!!!!!!! ;)
« Reply #9 on: 07 February 2010, 19:08:51 »
gearbox goes into limp as engine tells it to. Its well behaved, does what its told ;D
Remember, when ECU detects abnormalities (sensor issues), its running 'error handling' routines which are probably not the most intelligent, and designed to cover many different scenarios. Limp is purely a mode to get you home (or to garage), not for ongoing use :)
Humpy
« Reply #10 on: 07 February 2010, 19:18:52 »
Yes it has been replaced when I realised the displays are actually supposed to show something legible and I've got to get around to getting it re-programmed. It makes me smile everytime I see it. Simple things... :)
Humpy
« Reply #11 on: 07 February 2010, 20:10:14 »
Humpy
Worth a trip to Kevin Wood in Alton to get that sorted with tech2  :y
