Pages: [1] 2 3  All   Go Down
Author Topic: fault codes  (Read 4033 times)
prestigetravel
  • Leominster
fault codes
« on: 08 February 2010, 11:53:06 »
Since my previous post in november and some advice from a vauxhall technician i have changed my ecu and now the cars up and running. All lights out i have taken it for a run and when i pulled up at home the engine management light started flashing!!!
Have done pedal trick which has returned the following codes.
0100
0120
0220
0300
0301
0303
0305
I have read the codes sheet on the forum and gather 0100 is the maf,not a problem to change.
0120 and 0220 are throttle sensor probs, this is what vx technician told me are known for frying ecu.
the other codes relate to misfire on 3 cylinders.
Any ideas and suggestions gratly appreciated .
Re: fault codes
« Reply #1 on: 08 February 2010, 11:57:53 »
Codes here:
http://www.omegaowners.com/forum/YaBB.pl?num=1220619696
Never heard of throttle sensors frying an ECU  :-?
Re: fault codes
« Reply #2 on: 08 February 2010, 11:58:35 »
check the plugs for any oil / water
prestigetravel
  • Leominster
Re: fault codes
« Reply #3 on: 08 February 2010, 12:04:49 »
Cheers any idea which side of engine are cylinders 1,3 and 5
Re: fault codes
« Reply #4 on: 08 February 2010, 12:05:19 »
Driver`s
Re: fault codes
« Reply #5 on: 08 February 2010, 12:07:06 »
Fried ECU?  Believe that when I see it!
serek
  • huntingdon
    • 3.2 mv6
Re: fault codes
« Reply #6 on: 08 February 2010, 12:07:41 »
driver side :y
prestigetravel
  • Leominster
Re: fault codes
« Reply #7 on: 08 February 2010, 12:08:12 »
cheers will have a look.  any ideas on throttle fault?
Re: fault codes
« Reply #8 on: 08 February 2010, 12:09:42 »
Fix the obvious faults first (misfire on drivers side), the others may be red herrings
prestigetravel
  • Leominster
Re: fault codes
« Reply #9 on: 08 February 2010, 12:13:45 »
just removed all dry at plugs. As all 3 cylinders showing misfire could the coil strip pack be at fault?
Re: fault codes
« Reply #10 on: 08 February 2010, 12:18:26 »
yup, coil packs are known to fail, tempted to say swap them over, and see if the fault transfers to the other bank. But not sure you can do that  :-/
prestigetravel
  • Leominster
Re: fault codes
« Reply #11 on: 08 February 2010, 12:21:49 »
Cheers just looked on ebay £65 for genuine bosch one not to bad!
Re: fault codes
« Reply #12 on: 08 February 2010, 12:36:34 »
STOP.....a whole coil pack dying at once.....an ecu being fried by throttle issues.....we are into silly season here so lets get some background.
What was the original fault.
What were the codes before the ECU was changed
I say this as only the other day, I had a call from a Vx dealer asking me what could possibly be causing fumes to come from the front drivers side of a 2.2dti.....hence my confidence in thier ability is low.
prestigetravel
  • Leominster
Re: fault codes
« Reply #13 on: 08 February 2010, 12:56:40 »
No codes. Original issues were turn ign on, no eml or immob light. car would turn over but no spark, as battery was literally flat immob light would flash and car would start. once started eml lit up and tc light and car would only rev up by 100 rpm. leave running for an hour, turn off and wouldnt start again until battery flat to point of hardly turning over. plugged in on 5 different diagnostics systems could not connect to ecu. Pedal trick didnt work either.
By putting another ecu on now starts, revs up, all dash warning lights as should be!
Must have been problem with ecu as all works ok in that respect. Tried old one one again still no good.
Old ecu going to specialist let you know diagnosis.
Just now trying to solve fault code issues in case one was responsible for ecu failure, their are several listings across sites/forums on internet relating to throttle sensor taking out ecu on omega/vectra?
Re: fault codes
« Reply #14 on: 08 February 2010, 13:15:37 »
Well for a start, the Vectra never had this engine fitted to it.
So, fault codes:
0100 Mass or volume air flow circuit
0120 Throttle/PedalPosition Incorrect Ratio
0220 Throttle/pedalPosition sensor/switch "B" circuit
0300 Random/multiple cylinder misfire detected
0301 Cylinder 1 Misfire Detected
0303 Cylinder 3 Misfire Detected
0305 Cylinder 5 Misfire Detected
Your issues sound a little more fundamental to me, as many know, I dont buy into the multiple things failing at once way of thinking. If I did then I would change the ecu, coil pack, throttle sensor/unit and still have the fault.
So, what do we know, well we know that the items above are both high power jobs...i.e. gobble juice.
So I would be checking engine and ecu chassis connectiosn and supply wiring first!
As for the coil pack, its 3 seperate coils with a common 12V supply......and hence why 3 failing all at the same time does not fit the bill for me.
More investigation needed before WNPC takes over (because here on OOF we are beyond that)  :y
Note: WNPC = Willy Nilly Part Changing
« Last Edit: 08 February 2010, 13:16:38 by Mark »
Pages: [1] 2 3  All   Go Up
