Author Topic: Miss fire 3.0 MV6  (Read 1984 times)
Sir Popple
  • Roscommon, IRL (ex Cannock)
Miss fire 3.0 MV6
« on: 08 February 2010, 15:09:15 »
Hi all, Ok this all started Saturday I have a miss fire so i replaced all spark plugs this did not fix the problem!! I have just done the paper clip test, but do not get any fault codes other than the 12 and 31. So i have now removed each spark plug cap to find that cylinder 1 is not firing. should this show up as a fault code if the DIS Cap is faulty? or could it just be the lead?
Thanks
Re: Miss fire 3.0 MV6
« Reply #1 on: 08 February 2010, 15:18:22 »
Is it just 1 not firing? If so, HT leads.  If a pair aren't firing, DIS pack (depending which 2)
older ECU doesn't have misfire detection, so won't raise a code for it
Sir Popple
« Reply #2 on: 08 February 2010, 15:20:55 »
Hi, have only tried the drivers side as you know the issues at getting to the others, the other 2 on the drivers side are working fine
« Reply #3 on: 08 February 2010, 15:23:57 »
OK, you need to try all 6 :y
Sir Popple
« Reply #4 on: 08 February 2010, 15:25:06 »
Thanks, i thought you would say that  :(
« Reply #5 on: 08 February 2010, 15:37:14 »
I like to be predictable :P
Sir Popple
« Reply #6 on: 08 February 2010, 15:39:46 »
Never, just wish the nutter of an engineer that decided to root the wiring over the top of the spark plugs was within reach!!!!
« Reply #7 on: 08 February 2010, 15:42:01 »
Wait til you have to replace the DIS. Then you will know what moaning/swearing/pain is all about ;D
Sir Popple
« Reply #8 on: 08 February 2010, 15:44:23 »
THANKS, i can not wait!!!!! :-/
« Reply #9 on: 08 February 2010, 15:46:22 »
Shame they banned child labour  :-X
Sir Popple
« Reply #10 on: 08 February 2010, 15:50:43 »
I know, and Muffin the Mule is now illegal so i an told, know anywhere i can get a set of leads and a dis cap at the right price from? going for a coffee to contemplate for a while  :y
« Reply #11 on: 08 February 2010, 15:51:54 »
You need to find what it is first, and if the DIS Pack, which of the 3 types it is...
