Author Topic: Stalling when on ECO  (Read 3429 times)
Rob James
  • Sheffield
« on: 03 February 2010, 12:08:16 »
Hi,
A handful of times now the car has stalled, but only while it has been on ECO. Any ideas why this might be happening? I have noticed that when the fans come on to cool the engine the revs drop, so I'm wondering if these coming on occasionally causes it to stall?
Cheers,
Rob.
Re: Stalling when on ECO
« Reply #1 on: 03 February 2010, 12:28:45 »
ECO just disables the compressor, could be a red herring. Do a paperclip test  :y
« Last Edit: 03 February 2010, 12:28:58 by tunnie »
  • Online Online
« Reply #2 on: 03 February 2010, 12:36:27 »
But it also drops the revs.  ;)
Rob James
  • Sheffield
« Reply #3 on: 03 February 2010, 12:36:39 »
I'll do the paper clip test when my wife gets back with the car. My thought was that as the revs are higher with the compressor running it was preventing the car from stalling.
  • Online Online
« Reply #4 on: 03 February 2010, 12:39:17 »
Hi,
Cheers,
Rob.
ECO does knock the a/c compressor off, but also drops the revs - the engine doesn't need to rev as high as there's a little less load. It could be the idle air control valve that's gummed up & not reacting fast enough. Pretty sure there's a guide to cleaning it out somewhere. Clean it & go from there.
Fans take quite a load if they run up on full speed, same as above.  :y
  • Online Online
« Reply #5 on: 03 February 2010, 12:39:43 »
Yes!  :y
« Reply #6 on: 03 February 2010, 12:40:25 »
Did say could..... compressor drops it by about 100 rpm or so, not going to be a massive different, if ICV is being dogey would affect it in auto as well.
  • Online Online
« Reply #7 on: 03 February 2010, 12:43:11 »
......... compressor drops it by about 100 rpm or so,  ......
I've not looked for exact numbers but it's more of a difference than 100 rpm IIRC tick over on ECO is around 450-500 and in AUTO is more like 750/800 rpm
« Reply #8 on: 03 February 2010, 12:46:53 »
Must be more on V6, never noiced that much of a difference on mine  :-/ Its more noise than anything else, under ECO its much quieter on idle, i have to watch the rev dial very closely to see it even move  :-/
  • Online Online
« Reply #9 on: 03 February 2010, 12:50:58 »
Quite a noticable drop in revs & noise when climate is OFF or on ECO compared to AUTO. Years ago I sat waiting at the lights and my daughter decided to 'play' & turn the climate OFF. Her face was a picture as for a moment she thought she'd broken something ;D .... till I laughed at her cos I kinda knew what she was thinking!  ;D  ;D  ;D  ;D
« Reply #10 on: 03 February 2010, 12:56:59 »
Once in traffic, my hazzard warning lights came on. I blamed mother tunnie, but she said she did not do it. Couple of days later taking her to the shops she tried to turn on the heated seat, but also turned the hazzards on  ::)
mathewst
  • Split, Croatia
    • v40
« Reply #11 on: 03 February 2010, 13:01:03 »
A little advice.
ECO doesn't drop the revs but the climate increases them cause the compressor is turned on.
I know it sounds the same but it isn't.
It seems the minimum revs are the problem here (ICV probably).
mathewst
  • Split, Croatia
    • v40
« Reply #12 on: 03 February 2010, 13:03:25 »
Also one other possible problem.
Blocked injectors if the car did too many miles and simply not enough fuel is reaching into the engine or the spray pattern is not good so the car is stalling at low revs
  • Online Online
« Reply #13 on: 03 February 2010, 13:20:24 »
A little advice.
In practice it's the same thing!  :-?  :-?
mathewst
  • Split, Croatia
    • v40
« Reply #14 on: 03 February 2010, 13:39:26 »
Yep Andy but engines are designed to work normally without pushin the compressor.
Every electrical or mechanical extra gadget causes a load and increases fuel cons.
Also if it doesn't work normally without aircon definitelly emissions will be amess
