Author Topic: Alarm - again!!  (Read 1204 times)
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
Alarm - again!!
« on: 09 February 2010, 12:36:38 »
Had a problem initially with the alarm going off intermittently which I put down to duff battereies in the power sounder.  I replaced them and at the time it transpired that the separate alarm horn was duff so I replaced that as well.
Then I started to get 4 beeps on switch off which I believe is an indication of low voltage in the power sounder so I just whipped it off.
All's been fine for a month or so but now occasionally the horn alarm sounds for no good reason and the hazards flash.  I don't really want to spend my life locking it via the back door which I believe locks it without the alarm so any ideas or can I just disable the alarm in toto?
Moos3h
Re: Alarm - again!!
« Reply #1 on: 09 February 2010, 12:38:02 »
Rip that powersounder out!  Good bit of weight saving ;)
Re: Alarm - again!!
« Reply #2 on: 09 February 2010, 13:53:23 »
Disconnect bonnet switch, see if it still persists in arming
Welung666
Re: Alarm - again!!
« Reply #3 on: 09 February 2010, 13:54:50 »
 I was going to suggest that was the cause but you're just to quick Rob ;) ;D
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
Re: Alarm - again!!
« Reply #4 on: 09 February 2010, 15:38:03 »
As I said it's already been whipped out.
I'll give it a try.  I've heard that the bracket can bend but on my 02 car it's pretty substantial thing, or is it the actual plunger switch that is at fault?
