Author Topic: Levelling suspension  (Read 1603 times)
fingers21
  • march, cambs
« on: 09 February 2010, 20:19:36 »
I replaced a leaking pipe on my self levelling suspension the other day, now the whole back end of my car seems to sit VERY high. Is there a reset or something i need to do?
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: Levelling suspension
« Reply #1 on: 09 February 2010, 20:24:43 »
Check the arm on the sensor hasnt come off, R/H rear suspension arm
If it aint broken, you aint trying hard enough
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #2 on: 09 February 2010, 20:24:50 »
I did the same and duly noticed the same, I think it'a a case of, it was sagging  due to faulty shocks in the first place and now it's correct...   :)
fingers21
  • march, cambs
« Reply #3 on: 09 February 2010, 20:37:45 »
Ok, i popped the rose connector thing off, lifted the lever right up and started engine, it pumped the car to an amazing height, so i dropped the lever all the way down and nothing happened, didn't lower the car back down.
« Reply #4 on: 09 February 2010, 20:46:29 »
a guy had this a month or two ago, in his case it was the air release valve in the pump, which sits under the drivers head light, look up under the bumper and you'll see it.
The other possible is the sensor, chassis to suspesion arm drivers side of dif, there is a basic guide in maintenance on testing it, if the sensor arm is slowly lifted in increments and the car hight responds and stops at a relative position to it then i would suggest the release valve at fault, stick another pump in it from a breakers on here if they have one.
If the car just tops out no matter what you do with the sensor arm i guess its a sensor issue. Money on the pump release valve though i think.
There is no reset as such afaik, but to get the car down unclip the air hoses on the shock body, look in between wheel arch and top the tyre, you'll see the air line and r clip there. Pulling the r clip allows the connecter to come off and release the air, you may well need to jack it up to support the car while you do this, and to refit.
