Author Topic: 2.5 v6 select overheating!!!!!!!!  (Read 824 times)
martymadog
  • Grantown on Spey
« on: 08 February 2010, 20:39:19 »
Hi,there is two electric pumps either side of radiator for cooling fan, one on passenger side not working, I have checked and there is no power coming from wiring to pump!! Can anyone tell me if both pumps are linked via same fuse? Cant find any break in wiring but can only trace it back about 6" before it goes into loom!! cheers Marty
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: 2.5 v6 select overheating!!!!!!!!
« Reply #1 on: 09 February 2010, 00:53:50 »
think some one had same problem a wile ago and there is 2fuse's but cannot remeber were of hand. :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 09 February 2010, 07:12:07 »
there are two fuses for the front fans  i think they are 30 amp off the top of my head under the bonnet in the triangle shaped fusebox next to the battery. The two fuses are together so you should be able to spot them easy enough.
« Last Edit: 09 February 2010, 07:16:51 by Loo-knee »
martymadog
  • Grantown on Spey
« Reply #3 on: 09 February 2010, 21:33:32 »
Thanks boys, am sorted.
