Pages: [1] 2 3  All   Go Down
Author Topic: 0170 0173 codes  (Read 3487 times)
Martin_1962
0170 0173 codes
« on: 08 February 2010, 17:55:08 »
Got home and the emmisions light was on
I had some misfire codes - I ignore those - from a few days ago.
I had 0170 and 0173
Can anyone remember what they are for please?
Re: 0170 0173 codes
« Reply #1 on: 08 February 2010, 17:57:34 »
you should know where the codes are  ;)
http://www.omegaowners.com/forum/YaBB.pl?num=1220619696
P0170 Fuel trim malfunction (Bank 1)
P0173 Fuel trim malfunction (Bank 2)
Martin_1962
Re: 0170 0173 codes
« Reply #2 on: 08 February 2010, 18:06:41 »
Is this precat :(
Re: 0170 0173 codes
« Reply #3 on: 08 February 2010, 18:26:08 »
no, maf. same part as 3.2 i believe, search for the bosch part number on the maf it self.
pre cat is 0420 0430. iirc
Martin_1962
Re: 0170 0173 codes
« Reply #4 on: 08 February 2010, 18:27:08 »
I fitted one last year :o
Re: 0170 0173 codes
« Reply #5 on: 08 February 2010, 18:33:53 »
pattern? or you may have an air leak in inlet or exhaust, its a fuel air inbalance thing.
Martin_1962
Re: 0170 0173 codes
« Reply #6 on: 08 February 2010, 18:35:37 »
Pattern
I'll check for inlet leaks - hoses off ect.
Or is it LPG related?
Re: 0170 0173 codes
« Reply #7 on: 08 February 2010, 18:43:11 »
Pattern
KEVIIIIIIIN....?
i'll bet on maf but see what others say.
« Last Edit: 08 February 2010, 18:45:00 by chrisgixer »
Martin_1962
Re: 0170 0173 codes
« Reply #8 on: 09 February 2010, 10:07:27 »
Seems to run OK though.
So what is the likelyhood of yet another MAF?
Anyone near me who can lend one for testing?
Re: 0170 0173 codes
« Reply #9 on: 09 February 2010, 10:29:30 »
I would try it on petrol and see if it still occurs.
Basically, the ECU is having to adjust the fuelling too far to make the mixture correct. It's a problem on both banks, so that rules out Lambda sensors and exhaust leaks.
So - air leak into the intake system, a MAF problem or potentially LPG system in need of calibration / new filters / cleaning out of heavy ends IMHO.
Martin_1962
Re: 0170 0173 codes
« Reply #10 on: 09 February 2010, 10:34:13 »
I think the evaporator is on last legs
I wonder though if it is related to the cams and porting?
Re: 0170 0173 codes
« Reply #11 on: 09 February 2010, 11:11:26 »
Heavy ends?
Re: 0170 0173 codes
« Reply #12 on: 09 February 2010, 11:45:09 »
Irrelevant as its a closed loop system.....
Welung666
Re: 0170 0173 codes
« Reply #13 on: 09 February 2010, 12:09:54 »
Heavy ends?
Yes Chris, as opposed to the light ends ;D ;D ;D
Heavy ends = Long chain hydrocarbons and moisture in the tank from long term storage at depots and filling stations, basically crud in the bottom of the tank ;) :y
Martin_1962
Re: 0170 0173 codes
« Reply #14 on: 09 February 2010, 12:30:11 »
Heavy ends?
Evaporator cleaned out last year - not too many in there.
No filter
Plastic injectors
Pages: [1] 2 3  All   Go Up
